Trying to install node-red-contrib-ttn on a Multitech Conduit - running 5.0.0-AEP via the Manage palette
It keeps throwing the below errors -
Error: Command failed: npm WARN addRemoteGit Error: not found: git npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:63:19) npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:72:29) npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:81:16 npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5 npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/mode.js:8:5 npm WARN addRemoteGit at Object.oncomplete (fs.js:108:15) npm WARN addRemoteGit git+https://github.com/thethingsnetwork/api.git resetting remote /.npm/_git-remotes/https-github-com-thethingsnetwork-api-git-ff97a1b2 because of error: { [Error: not found: git] code: 'ENOGIT' } npm ERR! git clone --template=/.npm/_git-remotes/_templates --mirror https://github.com/thethingsnetwork/api.git /.npm/_git-remotes/https-github-com-thethingsnetwork ....
