My nodered has problem
a = 0;
while(a<=msg.payload.length){
if(msg.payload[a].ID == "D20A485C"){
msg.payload = {
"NAME" : msg.payload[a].NAME
}a++;
let a = 0;
    msg.payload = {
    break;
  a++;
Here is a much better, more modern way and avoids the risk of an infinite loop.
const entry = msg.payload.find(e=>e.ID == "D20A485C")
if (entry) {
  msg.payload = { "NAME" : entry.NAME };
  return msg
Thank you so muchhhh...it really help
Then, how to stop it after checking all the file...
I don't want it to return msg[not found] after check every column.
because it return like this, if the data not found
it will return TypeError : Cannot read properties of undefined (reading 'ID')
Difficult to tell from a screenshot an no sample data.
Can you select the bunch of related nodes & export the flow (CTRL+E) and paste the copied flow into a code block.
I will also need some sample data of the CSV (it can be fake but must be correct format)
Can we reply a message from telegram bot that end with _ (underscore)
Im trying to make this because each msg.payload could be different
