i open my node red using command prompt...but then the server load too long, and even if it can open the server, it cant be deployed second time...
You need to provide bit more information because no one can see what you are doing.
Take a read of this FAQ.
fyi, im doing a file system in nodered. [Before, it can be used normally, until i add telegram bot node...but even after deleting the telegram bot node, the problem still happen] Where after a student scan their IC to the RFID, the serial in will send the id tag to a file through nodered. Then if the card has been registered, it will continue to the next step which the telegram bot. and it will send data to arduino, that the card has been registered. If the card hasnt been registered, student will need their lecturer to register them.
So have this workd before and it just stopped working - or have you been making changes ?
Usually in this sort of situation it is a "race" condition where you have a message going around and around in circles either due to a programming issue - or a bug in a new node
Craig
but i put delay on the arduino....
What @craigcurtin means is somewhere in your flow you might be creating an infinite loop
This loop could be in the form of nodes wired to (directly or via other nodes/links/mqtt) back to itself
Or perhaps a for or while loop in a function.
Unless you share your flow (CTRL+E) we will not be able to help other than offer advice.
"id": "3f5da7085f233b28",
"type": "tab",
"label": "RFID - ACTUAL",
"disabled": false,
"info": "",
"env": []
"id": "dd015d94dacb7639",
"type": "debug",
"z": "3f5da7085f233b28",
"name": "OUTPUT - SCAN1",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 390,
"y": 100,
"id": "c099df188cdf337e",
"type": "mqtt out",
"topic": "scan/tagid",
"qos": "2",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"broker": "4c7850b0d02a178b",
"x": 390,
"y": 40,
"id": "465df20e9ba736f5",
"type": "mqtt in",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 120,
"y": 240,
"6df5a60399603ec3",
"62cbba8915789534"
"id": "6df5a60399603ec3",
"type": "ui_text",
"group": "1f556657e1b59fe7",
"order": 1,
"width": 0,
"height": 0,
"label": "ID TAG",
"format": "{{msg.payload}}",
"layout": "row-spread",
"className": "",
"x": 300,
"y": 200,
"id": "62cbba8915789534",
"type": "function",
"func": "flow.set(\"TAGID\",msg.payload)",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 300,
"y": 260,
"id": "3cc975cbdc1f7c96",
"type": "function",
"func": "//timestamp\nvar now = new Date();\nvar yyyy = now.getFullYear();\nvar mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1);\nvar dd = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\nvar hh = now.getHours();\nvar mmm = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\nvar ss = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds()\n\n//for csv file storage\nmsg.payload = {\n \"Date\": yyyy + \"-\" + mm + \"-\" + dd,\n \"Time\": hh + \":\" + mmm + \":\" + ss,\n \"ID\": flow.get(\"TAGID\")\n}\nmsg.filename = \"C:/Users/syafi/OneDrive/Desktop/IOT ASSIGNMENT BOX/try21111.csv\"\nreturn msg;\n\n\n\n\n\n\n\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1160,
"y": 100,
"ff5e87ef0243a93c"
"id": "ff5e87ef0243a93c",
"type": "csv",
"name": "SCAN1",
"sep": ",",
"hdrin": false,
"hdrout": "once",
"multi": "mult",
"ret": "\\r",
"temp": "Date,Time,ID",
"skip": "0",
"strings": true,
"include_empty_strings": false,
"include_null_values": "",
"x": 1320,
"y": 100,
"23928c77d1d16112"
"id": "23928c77d1d16112",
"type": "file",
"filename": "",
"appendNewline": true,
"createDir": true,
"overwriteFile": "false",
"encoding": "utf8",
"x": 1480,
"y": 100,
"id": "16b2ade87514e359",
"type": "comment",
"name": "CREATE A FILE ~ SCAN card",
"info": "",
"x": 1060,
"y": 40,
"id": "202020ceba2d88a5",
"type": "mqtt in",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 1000,
"y": 100,
"3cc975cbdc1f7c96"
"id": "3abd293812ee84d7",
"type": "ui_text_input",
"label": "NAME",
"tooltip": "",
"group": "3efc5a1282d3fc63",
"order": 2,
"width": 0,
"height": 0,
"passthru": true,
"mode": "text",
"delay": 300,
"topic": "topic",
"sendOnBlur": true,
"className": "",
"topicType": "msg",
"x": 1010,
"y": 360,
"f024deacb814c644"
"id": "d7dc586e065774ac",
"label": "CLASS",
"tooltip": "",
"order": 3,
"width": 0,
"height": 0,
"passthru": true,
"mode": "text",
"delay": 300,
"topic": "topic",
"sendOnBlur": true,
"className": "",
"topicType": "msg",
"x": 1020,
"y": 420,
"d3095115b35c0ec1"
"id": "e6c942a66d4c8190",
"label": "No. Phone",
"tooltip": "",
"order": 4,
"width": 0,
"height": 0,
"passthru": true,
"mode": "text",
"delay": 300,
"topic": "topic",
"sendOnBlur": true,
"className": "",
"topicType": "msg",
"x": 1030,
"y": 480,
"8582ace66ebf2996"
"id": "f024deacb814c644",
"type": "function",
"func": "flow.set(\"name\",msg.payload)",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1180,
"y": 360,
"id": "8582ace66ebf2996",
"type": "function",
"func": "flow.set(\"phono\",msg.payload)",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1180,
"y": 480,
"id": "d3095115b35c0ec1",
"type": "function",
"func": "flow.set(\"class\",msg.payload)",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1180,
"y": 420,
"id": "99cdca626db75abb",
"type": "ui_button",
"group": "d9ce59e45c2b7a9a",
"order": 4,
"width": 3,
"height": 1,
"passthru": false,
"label": "DONE",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"icon": "",
"payload": "false",
"payloadType": "bool",
"topic": "topic",
"topicType": "msg",
"x": 110,
"y": 620,
"4cf77cc913bc278e",
"85b2ae3b6c648d4a",
"fc9a3ae70f047992"
"id": "4cf77cc913bc278e",
"type": "function",
"func": "flow.set(\"donenew\",msg.payload)",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 320,
"y": 620,
"id": "6ca3008f94aa8ed7",
"type": "ui_led",
"order": 2,
"width": 3,
"height": 3,
"label": "",
"labelPlacement": "left",
"labelAlignment": "left",
"colorForValue": [
"color": "#413e3e",
"value": "false",
"valueType": "bool"
"color": "#20f320",
"value": "true",
"valueType": "bool"
"allowColorForValueInMessage": false,
"shape": "circle",
"showGlow": true,
"x": 570,
"y": 560,
"id": "85b2ae3b6c648d4a",
"type": "function",
"func": "var butS = flow.get(\"startnew\")\nvar butD = flow.get(\"donenew\")\n\n if(butS == true){\n msg.payload == true\n }\n else if(butD == false){\n msg.payload == false\n }\n\nflow.set(\"SDdata\", msg.payload)\nreturn msg;\n\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 440,
"y": 560,
"6ca3008f94aa8ed7"
"id": "d665a3fb3fd68a63",
"order": 1,
"width": 3,
"height": 1,
"passthru": false,
"label": "START",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"icon": "",
"payload": "true",
"topic": "topic",
"topicType": "msg",
"x": 120,
"y": 500,
"5620c1c7c8ce1851",
"85b2ae3b6c648d4a",
"fc9a3ae70f047992"
"id": "5620c1c7c8ce1851",
"type": "function",
"func": "flow.set(\"startnew\",msg.payload)",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 320,
"y": 500,
"id": "fc9a3ae70f047992",
"type": "mqtt out",
"topic": "DATAs/d",
"qos": "2",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"x": 240,
"y": 560,
"id": "6a9bd9882018a654",
"type": "csv",
"sep": ",",
"hdrin": "",
"hdrout": "once",
"multi": "one",
"ret": "\\n",
"temp": "NAME,CLASS,No. PHONE,ID",
"skip": "0",
"strings": true,
"include_empty_strings": true,
"x": 1370,
"y": 580,
"90cb6b75cf549b0a"
"id": "15cada6493cf5cc2",
"order": 6,
"width": 0,
"height": 0,
"passthru": false,
"label": "ENTER",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"icon": "",
"payload": "",
"payloadType": "str",
"topic": "topic",
"topicType": "msg",
"x": 1020,
"y": 580,
"7fd851356ece1df1"
"id": "7fd851356ece1df1",
"type": "function",
"name": "STUDENT DATA",
"func": "var N = flow.get(\"name\");\nvar C = flow.get(\"class\");\nvar PN = flow.get(\"phono\");\n\nmsg.payload = {\n \"ID\" : flow.get(\"TAGID\"),\n \"NAME\" : N,\n \"CLASS\": C,\n \"No. PHONE\": PN\n}\n\nmsg.filename = \"C:/Users/syafi/OneDrive/Desktop/IOT ASSIGNMENT BOX/INFO1.csv\"\nflow.set(\"enterdata\", msg.filename)\nreturn msg;\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1210,
"y": 580,
"6a9bd9882018a654"
"id": "90cb6b75cf549b0a",
"type": "file",
"filename": "",
"createDir": true,
"encoding": "utf8",
"x": 1540,
"y": 580,
"id": "ec7c9eb1ee225933",
"type": "comment",
"name": "CREATE A FILE ~ [STUDENT] CARD INFORMATION",
"info": "",
"x": 1140,
"y": 300,
"id": "8c60978695ac110d",
"type": "ui_text",
"order": 1,
"width": 0,
"height": 0,
"label": "INSTRUCTION",
"layout": "col-center",
"className": "",
"x": 1640,
"y": 340,
"id": "44d2a4ee09270ac2",
"type": "file in",
"filename": "C:/Users/syafi/OneDrive/Desktop/IOT ASSIGNMENT BOX/INFO1.csv",
"format": "utf8",
"chunk": false,
"sendError": false,
"encoding": "none",
"allProps": false,
"x": 470,
"y": 1100,
"9984b89c02f37ca3"
"id": "c155ddeab85ab25f",
"type": "mqtt in",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 120,
"y": 1100,
"44d2a4ee09270ac2"
"id": "9984b89c02f37ca3",
"type": "csv",
"sep": ",",
"hdrin": "",
"hdrout": "once",
"multi": "one",
"ret": "\\n",
"skip": "0",
"strings": true,
"x": 110,
"y": 1040,
"dcaa2b490433b515"
"id": "dcaa2b490433b515",
"type": "join",
"mode": "custom",
"build": "array",
"property": "payload",
"propertyType": "msg",
"key": "topic",
"joiner": "\\n",
"joinerType": "str",
"accumulate": false,
"timeout": "",
"count": "",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "",
"reduceFixup": "",
"x": 130,
"y": 940,
"beb77a26ec5af808"
"id": "beb77a26ec5af808",
"type": "function",
"name": "CHECK STUDENT DATA",
"func": "var id = flow.get(\"TAGID\");\nvar id1 = id.trim();\nvar a = 0;\nvar b = msg.payload.length - 1;\n\n//var length = msg.payload.length-1;\nwhile(a <= b){\n if(msg.payload[a].ID == id1){\n msg.payload = {\n state : \"V\",\n array : a,\n //len : length\n };\n }\nwhile(a == msg.payload.length){\n if(msg.payload[a].ID == id1){\n msg.payload = {\n state : \"V1\",\n array : a,\n //len : length\n };\n }\n else{\n msg.payload = \"U\"\n }\n }\n}\n a++;\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 330,
"y": 1000,
"82088bdf9a885beb"
"id": "82088bdf9a885beb",
"type": "split",
"splt": "\\n",
"spltType": "str",
"arraySplt": 1,
"arraySpltType": "len",
"stream": false,
"addname": "payload.content",
"x": 310,
"y": 940,
"0e9de7fa616cbcd7",
"1621243aea1aa584"
"id": "0e9de7fa616cbcd7",
"type": "function",
"func": "return msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 500,
"y": 920,
"c04608cb3f156e61"
"id": "1621243aea1aa584",
"type": "function",
"func": "\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 580,
"y": 980,
"06ec76dd49bb5e40"
"id": "bffc0e4037207bd9",
"type": "comment",
"name": "CHECK ARRAY FILE ~ SCANNED CARD",
"info": "",
"x": 200,
"y": 800,
"id": "c04608cb3f156e61",
"type": "mqtt out",
"topic": "card/state",
"qos": "2",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"broker": "a8d3e42c.4c3b68",
"x": 680,
"y": 860,
"id": "06ec76dd49bb5e40",
"type": "mqtt out",
"topic": "card/array",
"qos": "2",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"x": 700,
"y": 920,
"id": "9f8520f8a585b3ab",
"type": "serial out",
"serial": "44d5796bf210fd01",
"x": 410,
"y": 1240,
"id": "a71bab1dd333b207",
"type": "mqtt in",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 120,
"y": 1300,
"a1a3dc842b6432c4"
"id": "7e3673cad586c9c2",
"type": "mqtt in",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 120,
"y": 1240,
"1c55369ad7289138",
"9f8520f8a585b3ab"
"id": "1c55369ad7289138",
"type": "function",
"func": "flow.set(\"cstate\",msg.payload)",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 260,
"y": 1220,
"id": "a1a3dc842b6432c4",
"type": "function",
"func": "flow.set(\"carray\",msg.payload)",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 260,
"y": 1280,
"id": "af6618d58b23f91d",
"type": "function",
"d": true,
"name": "split data",
"func": "var splitmsg = msg.payload.split(\",\");\nvar msg1 = { payload: parseFloat(splitmsg[0]) };\nvar msg2 = { payload: parseFloat(splitmsg[1]) };\nvar msg3 = { payload: parseFloat(splitmsg[2]) };\n\n\nreturn [msg1, msg2, msg3];",
"outputs": 3,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 600,
"y": 60,
"id": "7410cf1ee3ccfe72",
"type": "mqtt in",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 120,
"y": 1400,
"id": "874f2dc3c03ce50a",
"type": "function",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 480,
"y": 1400,
"id": "f25a4912f041c010",
"type": "mqtt in",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 120,
"y": 320,
"4fd2a4268026df32",
"84a55fdfb103ae7e"
"id": "4fd2a4268026df32",
"type": "function",
"func": "var status = flow.get(\"cstate\");\n\nif(status == \"V\" || status == \"V1\"){\n msg.payload = \"VERIFIED\";\n}\nelse{\n msg.payload = \"UNVERIFIED\";\n}\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 300,
"y": 300,
"786f0fded237af42"
"id": "84a55fdfb103ae7e",
"type": "ui_text",
"order": 2,
"width": 0,
"height": 0,
"label": "STATUS : ",
"className": "",
"x": 300,
"y": 340,
"id": "dabdc6375a42d704",
"type": "function",
"func": "flow.set(\"statss\",msg.payload)",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 620,
"y": 200,
"id": "5b7fd83b2f3df23b",
"type": "mqtt in",
"topic": "DATAs/d",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 460,
"y": 200,
"dabdc6375a42d704"
"id": "3b3fb8cc7931d96b",
"type": "mqtt in",
"topic": "DATAs/d",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 1340,
"y": 360,
"c05ba9127d960c63"
"id": "c05ba9127d960c63",
"type": "function",
"func": "flow.set(\"statss\",msg.payload)\n\nvar what = flow.get(\"statss\");\n\nif(statss == \"VERIFIED\"){\n msg.payload = \"FILL UP STUDENT INFORMATION FIRST, THEN PRESS'ENTER' BUTTON\";\n}",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1480,
"y": 400,
"8c60978695ac110d"
"id": "786f0fded237af42",
"type": "mqtt out",
"topic": "DATAs/d",
"qos": "2",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"x": 440,
"y": 300,
"id": "6fc9fc0635ada31d",
"type": "serial in",
"serial": "d8cacf86.7e5d3",
"x": 150,
"y": 140,
"c099df188cdf337e",
"dd015d94dacb7639"
"id": "259c7ad3d95012ca",
"type": "ui_spacer",
"name": "spacer",
"group": "e394156bb9a5a8e4",
"order": 2,
"width": 3,
"height": 1
"id": "b91b80b1e3a72dbf",
"name": "spacer",
"order": 5,
"width": 3,
"height": 1
"id": "4c7850b0d02a178b",
"type": "mqtt-broker",
"broker": "broker.hivemq.com:1883",
"port": "1883",
"clientid": "",
"autoConnect": true,
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"sessionExpiry": "",
"info": "> Brightness ="
"id": "1f556657e1b59fe7",
"type": "ui_group",
"name": "SCAN TAG",
"tab": "4125baac87d6639c",
"order": 1,
"disp": true,
"width": "6",
"collapse": false,
"className": ""
"id": "3efc5a1282d3fc63",
"type": "ui_group",
"name": "GROUP2",
"order": 2,
"disp": true,
"width": "6",
"collapse": false,
"className": ""
"id": "d9ce59e45c2b7a9a",
"type": "ui_group",
"name": "SECTION 2 ~ NEW INFORMATION",
"order": 3,
"disp": true,
"width": "6",
"collapse": false,
"className": ""
"id": "a8d3e42c.4c3b68",
"port": "1883",
"clientid": "",
"usetls": false,
"compatmode": false,
"keepalive": "60",
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"sessionExpiry": ""
"id": "44d5796bf210fd01",
"type": "serial-port",
"serialport": "COM3",
"serialbaud": "9600",
"databits": "8",
"parity": "none",
"stopbits": "1",
"waitfor": "",
"dtr": "none",
"rts": "none",
"cts": "none",
"dsr": "none",
"newline": "\\n",
"bin": "false",
"out": "char",
"addchar": "",
"responsetimeout": "10000"
"id": "d8cacf86.7e5d3",
"databits": "8",
"parity": "none",
"stopbits": "1",
"waitfor": "",
"newline": "\\r",
"bin": "false",
"out": "char",
"addchar": "false",
"id": "4125baac87d6639c",
"type": "ui_tab",
"name": "RFID - NOV",
"icon": "dashboard",
"order": 11,
"disabled": false,
"hidden": false
this one has been solved
It could be helpful for others in the future if you explained what the problem was and what you did to fix it.
Sure, i didnt do anything actually....I just close and open it back several time actually
I seem to found the problem here, i put a looping in a function node[check array].
While loop....
But that part is the most important thing for my system
Can you explain what the loop does & show us the code (as text in a code block (not a screenshot))
Well, I put a while loop inside a function node. It is for me to search inside an array(that is from the file)
while(a<=msg.payload.length){
if(msg.payload[a].ID == "D20A485C"){//UID TAG
msg.payload = {
"NAME" : msg.payload[a].NAME
Could anyone suggest a way far me to search which UIDTAG(msg.payload[arraynum].UIDTAG) that has the same with inside an array that converted from a file(that content NAME, CLASS, NO. PHONE, UIDTAG).
In that code example you just posted, the value of “a” is never changed, so the while loop would never end.
how should i end it?
