Today when I went to push some new changes to git hub I noticed that when I clicked the project history tab it doesn't populate, it is just a gray rectangle. Up to this point it's been working great, and I've made dozens of commits this way.
I double-checked my settings.js file, and everything looks to be in order -- the projects enabled section is set to true.
Under the project settings, my Git Remotes origin field points to the correct github URL.
I tried blowing away the settings.js file and re-modifying it so projects are enabled, but the result is the same. Has anyone experienced this before or knows what's going on? I have some changes to check in that I really don't want to lose.
Thanks!
