Nbrower node : Saveas doesn't work?
Hi i use this flow to save a web page into a pdf file :
        "id": "129d963431e3975c",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "a1c3b5dc9d7fc22e",
        "type": "nbrowser",
        "z": "129d963431e3975c",
        "name": "test",
        "methods": [
                "name": "gotoURL",
                "func": "goto",
                "params": [
                        "type": "msg",
                        "value": "payload",
                        "typeDefault": "str"
                "name": "saveAs",
                "func": "saveAs",
                "params": [
                        "type": "saveAction",
                        "value": "pdf",
                        "typeDefault": "saveAction"
                        "type": "str",
                        "value": "/data/pdf/test.pdf",
        "prop": "nbrowser",
        "propout": "payload",
        "object": "msg",
        "objectout": "msg",
        "close": false,
        "show": true,
        "ssl": true,
        "outputs": 1,
        "x": 410,
        "y": 100,
        "id": "27100f4dbdee757d",
        "type": "inject",
        "name": "https://flows.nodered.org/",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "https://flows.nodered.org/",
        "payloadType": "str",
        "x": 170,
        "y": 100,
                "a1c3b5dc9d7fc22e"
But the file is not created. I forgot something ?
An idea ?
Hi, in order to make code more readable and importable it is important to surround your code with three backticks
 like this
You can edit and correct your post by clicking the pencil icon.
Done thx !
Well since your flow is only 2 nodes an inject and an nBrowser node - you are not doing anything with the result so you wont save anything.
I'm surprised because i thought that nbrowser was supposed to do the job :
My debug node show me nothing and the debug window remains empty after the injection.
My apologies, I have not used that node - I wrongly assumed it would output something from the output pin - for you to save.
Does it work if you select other save as type?
Does the path /data/pdf/ exist & can you access it (is this a docker node-red? and if so, do you know how to access /data/pdf/ to check if the file is written?)
Are there any errors in node-red terminal / log?
Yes the path exist, i have all rights (RW) and i can access to this folder, node red (the docker) too. I have no error message. It's strange.
I found an error in the.npm/logs folder :
27 Jan 15:33:41 - [red] Uncaught Exception:
27 Jan 15:33:41 - [error] Error: spawn /data/node_modules/electron/dist/electron ENOENT
at Process.ChildProcess._handle.onexit (internal/child_process.js:274:19)
at onErrorNT (internal/child_process.js:469:16)
at processTicksAndRejections (internal/process/task_queues.js:82:21)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! node-red-docker@2.1.6 start: node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data"
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the node-red-docker@2.1.6 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /data/.npm/_logs/2022-01-27T15_33_41_042Z-debug.log
node-red-docker@2.1.6 start /usr/src/node-red
But i don't understand the problem.
how have you installed node-red?
Is node-red installed in docker or directly?
What hardware and OS is this running on?
Are you running an electron version of node-red?
It's a docker with a data folder with all rights (RW)
I use Portainer in my Qnap NAS to install the docker but I access to node red with a mac
I guess I don't run an electron version (how can i know that ? )
Thx
I only asked as i seen this...
Do you have a standard installation of node-red (like on your MAC or a raspberry pi) that you can try this - to rule out the usual docker issues?
I think i'm going to try to find another node to do the job. I don't know if it exists.
