I am trying to use NBrowser, and want to scrape data from webpage which requires a login.
Does anyone have any config flows they can share to get me started?
I have downloaded NBrowser and Credentials, however I am struggling to setup the flows.
Thanks.
Are you sure you could not get the data using an API?
If not, then install: topological-nodered-wdio (node) - Node-RED
This lets you completely automate a series of webpages.
There are dependencies.
Java
selenium-standalone
You would need to understand basic selenium selectors.
Cheers,
Paul
Is there a problem with this?
node-red-contrib-nbrowser (node) - Node-RED (nodered.org)
There are also several nodes that run Puppeteer instead.
And note that you could call your browser headless:
"C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --headless --disable-gpu --enable-logging --dump-dom https://nodered.org
Which works with Chrome as well - I think that Firefox has something similar.
By the way, this comes up often enough that it prompted me to write a new FAQ:
Http-request node does not get all the page data (AKA How to scrape dynamic data from a web page) - FAQs - Node-RED Forum (nodered.org)
Thanks, I run NR in home assistant, do I need to run chrome on a remote machine when using Puppeteer or does chrome run headless as part of Puppeteer?
Thanks.
I believe that Puppeteer will include a version of Chrome - though honestly, I so rarely use it (and generally on a Windows PC anyway for that kind of thing) that I'm not totally sure. I expect that the Puppeteer docs will tell you for sure. Or just try it and see.
