Need a nudge in the right direction with msg.params
Hi
I am using the Spotify node, and having a lot of fun!
I have simple nodes - play, pause, skip working.
Now I need to use the node with some additional input parameters.
I have found the documentation at the bottom of this page: GitHub - pckhib/node-red-contrib-spotify: Node-RED node for Spotify Web API
I understand what the doc is telling me to do, and how it relates to my goals, but I lack the detailed knowledge to actually do it!
I know I need an inject node to contain the arguments and pass them to the spotify node. I know where to find the parameters in the spotify api documentation. I just don't know how to add a msg.params object, and how to format it.
I would appreciate some gap-filler.
Brendon
You can simply add a function node and enter the code example...
// API function: getArtistAlbums
msg.params = [
    '43ZHCT0cAZBISjO8DG9PnE', /* Artist ID */
    { limit: 10, offset: 20 } /* Options */
Trigger it by whatever you want (an inject for example)
