Neopixel node-red:rpi-gpio.status.not-available
Im trying to get my neopixel to work but I keep getting the error: node-red:rpi-gpio.status.not-available.
I'm using a raspberry pi 4 with a fresh install of the default os.
        "id": "475b960ba1324373",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "68f9499a0c156161",
        "type": "rpi-neopixels",
        "z": "475b960ba1324373",
        "gpio": "12",
        "pixels": "24",
        "bgnd": "",
        "fgnd": "",
        "wipe": "40",
        "mode": "pcent",
        "rgb": "rgb",
        "brightness": "100",
        "gamma": true,
        "x": 790,
        "y": 140,
        "id": "1d3327fdda6512cb",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 400,
        "y": 140,
                "1085fb7bb4a5ab9e"
        "id": "1085fb7bb4a5ab9e",
        "type": "function",
        "name": "function 1",
        "func": "msg.payload = 'Orange';\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 580,
        "y": 140,
                "68f9499a0c156161",
                "9355e0ea1681d292"
        "id": "9355e0ea1681d292",
        "type": "debug",
        "name": "debug 1",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 780,
        "y": 100,
Does anyone know how I can fix this or what could be the cause?
There is a bit more stuff you have to do in the RasPi setup.
Alas that machine is now offline and I can't boot it. Sorry.
This may help - I hope:
Last post.
It seems that you need these 4 lines:
hdmi_force_hotplug=1
hdmi_force_edid_audio = 1
hdmi_group=2
hdmi_mode=39
I was recently (as in very) messing around and the LEDs stopped working again.
This is/was because I use VNC and had changed the resolution of the screen to better fit the monitor.
When I looked at the /boot/config.txt the hdmi_mode and hdmi_group were set to something else.
Putting them to what is shown, the LED's started to work again.
Did you install the Pre-requisit?
