Nested Groups in Dashboard
I am likely going down the path of UIBuilder because I have such specific desires for my smarthome controls, but I just want to verify that I am not overlooking something.
Is there a way in the native NR dashboard to build nested groups?
I think the supported hierarchy is limited (in a reasonable way) to:
  • 1 Dashboard per NR instance
  • 1-N Tabs per Dashboard
  • 1-N Groups per Tab
  • 1-N Components per Group
I am not asking as an off-hand request for enhancement, I just want to make sure I am not missing something that might exist that I am just not seeing.
For what it is worth, I use a tab for Smarthome with other tabs for other things. I use a group per room and would plan to eventually subdivide that (probably hand built in UI builder) into capabilities like on/off/toggle vs. brightness vs. color picking.
You are correct. No nested groups - there is a proposal for that - but nowhere near completion and other constraints will still apply.
Thanks for the verification. As I suspected, UIBuilder is the way to go for those who are wanting to tweak a dashboard in an unconstrained way.
