NetAtmo get station data
[{"id":"5dfd7c4fa8812f8b","type":"tab","label":"Netatmo New","disabled":false,"info":"","env":[]},{"id":"37c406c4251df006","type":"group","z":"5dfd7c4fa8812f8b","name":"retrieve data from Net Atmo","style":{"fill":"#ffefbf","fill-opacity":"0.18","label":true},"nodes":["227b570a0ddb37d6","c90883e30af7414f","a6497c641eae2d3d","f03d6a1770671654","43cea1af6281e150","4272b4f37aaa8d85","d705af61f82a51a0","ccf05151b8977a17","b2aee11227c34965","06d4b90b7b3e2087","ead7a83a276da6d5","5b801eefb73d69e8","cbac66eef3ac6f68","f64a1f7a539e19ae","d09a9e75c1cb3fd9","39c95ea1197778ad"],"x":74,"y":579,"w":1792,"h":382},{"id":"1e6ac73d16d3e4fd","type":"group","z":"5dfd7c4fa8812f8b","name":"start and refresh access data","style":{"fill":"#ffefbf","fill-opacity":"0.18","label":true},"nodes":["35b6ddece06e5a06","d273766e96d450e0","6ceb42cb69397e82","6247f8cc1cc3880c","fe38821d7708d05c","5d156d10e7192948","f4794e23ba9db104","a6e99594aa88149d","549a3c451e797ba0","a2a6fbccd8054ab7","fde679bf6c4b3a78","b50c27c613f7bfda","37572cdd83c4a88e"],"x":74,"y":339,"w":1632,"h":202},{"id":"f1d3eb19dd08efed","type":"group","z":"5dfd7c4fa8812f8b","name":"set NetAtmo credetials","style":{"fill":"#ffefbf","fill-opacity":"0.18","label":true},"nodes":["033f7ad3bdf1e1f8","7537a9afc9d0ce1a"],"x":74,"y":99,"w":492,"h":82},{"id":"7bdfafd0d061bf13","type":"group","z":"5dfd7c4fa8812f8b","name":"single HTTP request","style":{"fill":"#ffefbf","fill-opacity":"0.18","label":true},"nodes":["472e545334afadc6","2df1498ab5d28910","424bd2e4540e6da0"],"x":84,"y":219,"w":402,"h":82},{"id":"75adeef4d28b4d5f","type":"group","z":"5dfd7c4fa8812f8b","name":"error handling","style":{"fill":"#ffefbf","fill-opacity":"0.18","label":true},"nodes":["c3d6f0104c69996d","1fc4771ca6ce3334","97d79dc47576aa9f","d92a122a85e3b0cc","653ae61d5333b989","bb043a8f9a80d5ea"],"x":74,"y":999,"w":732,"h":122},{"id":"b50c27c613f7bfda","type":"junction","z":"5dfd7c4fa8812f8b","g":"1e6ac73d16d3e4fd","x":500,"y":380,"wires":[["d273766e96d450e0"]]},{"id":"35b6ddece06e5a06","type":"inject","z":"5dfd7c4fa8812f8b","g":"1e6ac73d16d3e4fd","name":"Start","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"1","topic":"","payload":"","payloadType":"date","x":170,"y":380,"wires":[["b50c27c613f7bfda"]]},{"id":"d273766e96d450e0","type":"change","z":"5dfd7c4fa8812f8b","g":"1e6ac73d16d3e4fd","name":"Set param request & refresh","rules":[{"t":"set","p":"method","pt":"msg","to":"POST","tot":"str"},{"t":"set","p":"url","pt":"msg","to":"https://api.netatmo.com/oauth2/token","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"{\"grant_type\":\"refresh_token\",\"refresh_token\":$globalContext(\"NetatmoRefreshToken\"),\"client_id\":$globalContext(\"NetatmoClientId\"),\"client_secret\":$globalContext(\"NetatmoClientSecret\")}","tot":"jsonata"},{"t":"set","p":"headers[\"content-type\"]","pt":"msg","to":"application/x-www-form-urlencoded","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":440,"wires":[["37572cdd83c4a88e"]]},{"id":"6ceb42cb69397e82","type":"change","z":"5dfd7c4fa8812f8b","g":"1e6ac73d16d3e4fd","name":"Store tokens & delay","rules":[{"t":"set","p":"NetatmoAccessToken","pt":"global","to":"payload.access_token","tot":"msg"},{"t":"set","p":"NetatmoRefreshToken","pt":"global","to":"payload.refresh_token","tot":"msg"},{"t":"set","p":"delay","pt":"msg","to":"payload.expires_in*1000-300000","tot":"jsonata"},{"t":"set","p":"status","pt":"msg","to":"OK","tot":"str"},{"t":"set","p":"NetatmoLastUpdateTime","pt":"global","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":1280,"y":380,"wires":[["f4794e23ba9db104","a6e99594aa88149d"]]},{"id":"033f7ad3bdf1e1f8","type":"change","z":"5dfd7c4fa8812f8b","g":"f1d3eb19dd08efed","name":"Set Netatmo Creds & Tokens","rules":[{"t":"set","p":"NetatmoClientId","pt":"global","to":"","tot":"str"},{"t":"set","p":"NetatmoClientSecret","pt":"global","to":"","tot":"str"},{"t":"set","p":"NetatmoAccessToken","pt":"global","to":"581352d2e6da23fa898b49ae|f849008b26ca2aeb84a459cea673f283","tot":"str"},{"t":"set","p":"NetatmoRefreshToken","pt":"global","to":"581352d2e6da23fa898b49ae|fe902827ce3f122f9b0840592c3334b2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":140,"wires":[[]]},{"id":"7537a9afc9d0ce1a","type":"inject","z":"5dfd7c4fa8812f8b","g":"f1d3eb19dd08efed","name":"Set first info","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":190,"y":140,"wires":[["033f7ad3bdf1e1f8"]]},{"id":"6247f8cc1cc3880c","type":"inject","z":"5dfd7c4fa8812f8b","g":"1e6ac73d16d3e4fd","name":"Stop","props":[{"p":"reset","v":"1","vt":"num"},{"p":"status","v":"STOP","vt":"str"},{"p":"delay","v":"1","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":170,"y":480,"wires":[["f4794e23ba9db104","fde679bf6c4b3a78"]]},{"id":"fe38821d7708d05c","type":"switch","z":"5dfd7c4fa8812f8b","g":"1e6ac73d16d3e4fd","name":"All ok ?","property":"payload","propertyType":"msg","rules":[{"t":"hask","v":"access_token","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1040,"y":440,"wires":[["6ceb42cb69397e82"],["5d156d10e7192948"]],"outputLabels":["Response OK","Error"]},{"id":"5d156d10e7192948","type":"change","z":"5dfd7c4fa8812f8b","g":"1e6ac73d16d3e4fd","name":"Delay 1 hour on error","rules":[{"t":"set","p":"delay","pt":"msg","to":"3600000","tot":"num"},{"t":"set","p":"status","pt":"msg","to":"KO","tot":"str"},{"t":"set","p":"NetatmoLastUpdateTime","pt":"global","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":1280,"y":500,"wires":[["f4794e23ba9db104","a6e99594aa88149d"]]},{"id":"f4794e23ba9db104","type":"delay","z":"5dfd7c4fa8812f8b","g":"1e6ac73d16d3e4fd","name":"Refresh","pauseType":"delayv","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":440,"y":440,"wires":[["d273766e96d450e0"]]},{"id":"a6e99594aa88149d","type":"delay","z":"5dfd7c4fa8812f8b","g":"1e6ac73d16d3e4fd","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"outputs":1,"x":1600,"y":420,"wires":[["549a3c451e797ba0"]]},{"id":"549a3c451e797ba0","type":"function","z":"5dfd7c4fa8812f8b","g":"1e6ac73d16d3e4fd","name":"Next refresh in...","func":"var d = new Date();\nvar n = d.getTime();\nvar start_time = global.get('NetatmoLastUpdateTime')||0;\nvar duration = msg.delay/1000;\nvar elapsed_time = Math.round((n - start_time)/1000);\n\nvar remains = new Date(null);\nremains.setSeconds(duration - elapsed_time); // specify value for SECONDS here\nvar remains_h = remains.toISOString().substr(11, 8);\nif (msg.status == \"STOP\") {\n    node.status({});\n    msg.remains = \"00:00:00\";\n    msg.payload = 0;\n    return [null, msg];\n}\nif (elapsed_time < duration) {\n    node.status({fill:msg.status == \"OK\" ? \"blue\" : \"red\",shape:\"dot\", text:remains_h});\n    msg.remains = remains_h;\n    return [ msg, null ];\n}\n\n","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1600,"y":480,"wires":[["a6e99594aa88149d"],[]]},{"id":"227b570a0ddb37d6","type":"change","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"set pram request","rules":[{"t":"set","p":"method","pt":"msg","to":"GET","tot":"str"},{"t":"set","p":"url","pt":"msg","to":"https://api.netatmo.com/api/getstationsdata","tot":"str"},{"t":"set","p":"headers[\"Authorization\"]","pt":"msg","to":"\"Bearer \" & $globalContext(\"NetatmoAccessToken\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":760,"wires":[["d09a9e75c1cb3fd9"]]},{"id":"c90883e30af7414f","type":"inject","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"Get Netatmo Data","props":[{"p":"payload"}],"repeat":"300","crontab":"","once":false,"onceDelay":"10","topic":"","payload":"","payloadType":"date","x":210,"y":760,"wires":[["227b570a0ddb37d6"]]},{"id":"a6497c641eae2d3d","type":"mqtt in","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"","topic":"Net_Atmo_record","qos":"0","datatype":"auto-detect","broker":"99603ece.52e2a","nl":false,"rap":true,"rh":0,"inputs":0,"x":1520,"y":740,"wires":[["f03d6a1770671654"]]},{"id":"f03d6a1770671654","type":"debug","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"netatmo record in","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1730,"y":740,"wires":[]},{"id":"43cea1af6281e150","type":"inject","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"Test","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":250,"y":820,"wires":[["227b570a0ddb37d6"]]},{"id":"a2a6fbccd8054ab7","type":"link in","z":"5dfd7c4fa8812f8b","g":"1e6ac73d16d3e4fd","name":"stop-in","links":["fde679bf6c4b3a78"],"x":1335,"y":440,"wires":[["a6e99594aa88149d","549a3c451e797ba0"]]},{"id":"fde679bf6c4b3a78","type":"link out","z":"5dfd7c4fa8812f8b","g":"1e6ac73d16d3e4fd","name":"stop-out","mode":"link","links":["a2a6fbccd8054ab7"],"x":395,"y":500,"wires":[]},{"id":"4272b4f37aaa8d85","type":"switch","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"body?","property":"payload","propertyType":"msg","rules":[{"t":"hask","v":"body","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":930,"y":760,"wires":[["b2aee11227c34965","ccf05151b8977a17","d705af61f82a51a0","5b801eefb73d69e8","ead7a83a276da6d5"],["39c95ea1197778ad"]]},{"id":"d705af61f82a51a0","type":"mqtt out","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"Net_Atmo_record","topic":"Net_Atmo_record","qos":"0","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"99603ece.52e2a","x":1270,"y":740,"wires":[]},{"id":"5b801eefb73d69e8","type":"link out","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"link out 2","mode":"link","links":["9ceca7067dab4533","f122c9b8706c128b"],"x":1195,"y":800,"wires":[]},{"id":"ccf05151b8977a17","type":"function","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"time / record counter","func":"let counter = context.get(\"counter\");\ncounter = counter + 1;\ncontext.set(\"counter\", counter);\n\nlet time = moment().tz(\"Europe/Berlin\").format(\"HH:mm:ss\");\nnode.status({ fill: \"green\", shape: \"dot\", text: time + \" / \" + counter });\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\n\ncontext.set(\"counter\", 0);\n","finalize":"","libs":[{"var":"moment","module":"moment"},{"var":"momentTimezone","module":"moment-timezone"}],"x":1280,"y":680,"wires":[[]]},{"id":"ead7a83a276da6d5","type":"trigger","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"watchdog","op1":"","op2":"","op1type":"nul","op2type":"date","duration":"20","extend":true,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1240,"y":840,"wires":[["cbac66eef3ac6f68"]]},{"id":"f64a1f7a539e19ae","type":"link out","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"link out 258","mode":"link","links":["4aa91ee5.08bf2"],"x":1485,"y":840,"wires":[]},{"id":"cbac66eef3ac6f68","type":"function","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"watchdog","func":"let text = \"NetAtmo länger als 20 min offline!\";\nreturn { payload: { 'room': 'error', 'value': text } };","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1380,"y":840,"wires":[["f64a1f7a539e19ae"]]},{"id":"b2aee11227c34965","type":"debug","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"status","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload.status","targetType":"msg","statusVal":"payload.status","statusType":"auto","x":1230,"y":620,"wires":[]},{"id":"06d4b90b7b3e2087","type":"switch","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"object?","property":"payload","propertyType":"msg","rules":[{"t":"istype","v":"object","vt":"object"},{"t":"istype","v":"string","vt":"string"}],"checkall":"true","repair":false,"outputs":2,"x":800,"y":760,"wires":[["4272b4f37aaa8d85"],[]]},{"id":"472e545334afadc6","type":"http request","z":"5dfd7c4fa8812f8b","g":"7bdfafd0d061bf13","name":"","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":270,"y":260,"wires":[["424bd2e4540e6da0"]]},{"id":"2df1498ab5d28910","type":"link in","z":"5dfd7c4fa8812f8b","g":"7bdfafd0d061bf13","name":"request_in","links":[],"x":125,"y":260,"wires":[["472e545334afadc6"]]},{"id":"424bd2e4540e6da0","type":"link out","z":"5dfd7c4fa8812f8b","g":"7bdfafd0d061bf13","name":"link out 273","mode":"return","links":[],"x":445,"y":260,"wires":[]},{"id":"d09a9e75c1cb3fd9","type":"link call","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"call request","links":["2df1498ab5d28910"],"linkType":"static","timeout":"30","x":650,"y":760,"wires":[["06d4b90b7b3e2087"]]},{"id":"37572cdd83c4a88e","type":"link call","z":"5dfd7c4fa8812f8b","g":"1e6ac73d16d3e4fd","name":"call request","links":["2df1498ab5d28910"],"linkType":"static","timeout":"30","x":890,"y":440,"wires":[["fe38821d7708d05c"]]},{"id":"c3d6f0104c69996d","type":"catch","z":"5dfd7c4fa8812f8b","g":"75adeef4d28b4d5f","name":"All errors","scope":null,"uncaught":false,"x":160,"y":1080,"wires":[["d92a122a85e3b0cc"]]},{"id":"1fc4771ca6ce3334","type":"link out","z":"5dfd7c4fa8812f8b","g":"75adeef4d28b4d5f","name":"link out 300","mode":"link","links":["d3422b90f8530fb4"],"x":615,"y":1080,"wires":[]},{"id":"97d79dc47576aa9f","type":"debug","z":"5dfd7c4fa8812f8b","g":"75adeef4d28b4d5f","name":"debug  NetAtmo","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":680,"y":1040,"wires":[]},{"id":"d92a122a85e3b0cc","type":"function","z":"5dfd7c4fa8812f8b","g":"75adeef4d28b4d5f","name":"Time + Fehlermeldung","func":"if (msg.payload.type === \"reset\"){\n    node.status({ fill: \"green\", shape: \"dot\", text: \" \" });\n    return null;\n}\n\nlet counter = context.get(\"counter\");\ncounter = counter + 1;\ncontext.set(\"counter\", counter);\n\nlet time = moment().tz(\"Europe/Berlin\").format(\"DD-MM-YYYY HH:mm:ss\");\n\nlet text = \"Fehlerzeitpunkt: \" + time + \" / \" +\n    \"RPI 201\" + \" / \" +\n    \"Flow: netatmo EGWZ sensor\" + \" / \" +\n    \"Fehlermeldung: \" + msg.error.message + \" / \" +\n    \"Fehler ID: \" + msg.error.source.id + \" / \" +\n    \"Fehlertyp: \" + msg.error.source.type + \" / \" +\n    \"Fehlernode: \" + msg.error.source.name + \" / \" +\n    \"Fehlerzähler: \" + msg.error.source.count;\n    \nnode.status({ fill: \"red\", shape: \"dot\", text: text + \" / \" + counter });\n\nreturn{payload:text};","outputs":1,"timeout":"","noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\nif (context.get(\"counter\") === undefined) {\n    context.set(\"counter\", 0);\n}","finalize":"","libs":[{"var":"moment","module":"moment"},{"var":"momentTimezone","module":"moment-timezone"}],"x":420,"y":1080,"wires":[["1fc4771ca6ce3334"]]},{"id":"653ae61d5333b989","type":"link in","z":"5dfd7c4fa8812f8b","g":"75adeef4d28b4d5f","name":"debug","links":["198aa8893d75f395","e0b35f90dd344f8f","39c95ea1197778ad"],"x":505,"y":1040,"wires":[["97d79dc47576aa9f","1fc4771ca6ce3334"]]},{"id":"bb043a8f9a80d5ea","type":"inject","z":"5dfd7c4fa8812f8b","g":"75adeef4d28b4d5f","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":"1","topic":"","payload":"{\"type\":\"reset\"}","payloadType":"json","x":200,"y":1040,"wires":[["d92a122a85e3b0cc"]]},{"id":"39c95ea1197778ad","type":"link out","z":"5dfd7c4fa8812f8b","g":"37c406c4251df006","name":"to dedug","mode":"link","links":["653ae61d5333b989"],"x":1195,"y":920,"wires":[]},{"id":"99603ece.52e2a","type":"mqtt-broker","broker":"10.0.0.43","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":4,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","willTopic":"","willQos":"0","willPayload":""}]
Unfortunately there is a problem. The first request works ok but when it should request a second time for a new token it fails and I cannot figuere out what the probelem is.
The flow above is based on this flow in the node-red flow library
flow
which works.
If someone could help me find the problem it is very appreciated.
Not sure why you didnt use the oauth2 nodes, some time ago I posted a flow that works (i see that you participated in the discussion)
This does the same as your complete flow.
thanks for the tip! I just didn't remember your post :wink:
the difference to your flow is that I get my credentiels with the help of Postman which means some cut and paste before I can start.
So the oauth2 node is much smarter. I will give it a try.
The difference to your requirement is that I want the dashboard data and not rain and wind
little progress report:
based on your input I have reworked my flow. It works now perfectly since more than 12 hours.
next step is to get node-red-oauth2 to load my credentials which at the moment come from Postman using copy and paste.
my working flow without oaut2 nodes and little changes to the picture above.
You have to get the the tokens from postman or equivalent software.
[{"id":"d557eb264b53eeb0","type":"tab","label":"Netatmo New","disabled":false,"info":"","env":[]},{"id":"d508edfc10ca96d0","type":"group","z":"d557eb264b53eeb0","name":"retrieve data from Net Atmo","style":{"fill":"#ffefbf","fill-opacity":"0.18","label":true},"nodes":["7737a67081eef4e8","0443074dd4250d9c","3a5362954f199d3f","db5a4a411ed57be8","f1eec459e2893317","17d01814707624be","89225a8f357232c5","12cb8cc73743c2ce","a1e6861787c7b9cd","949e6679a2befee3","6b8ba085179f4f56","400352be8a87340e","a6600fbe65e81cc1","74f8e9dde28cfcb1","df92a998996ce415","3adc726ebd0aa92a","960cea8488046a64","7f0d116c40b05764"],"x":94,"y":559,"w":1572,"h":322},{"id":"05a20f826b31f5bf","type":"group","z":"d557eb264b53eeb0","name":"start and refresh access data","style":{"fill":"#ffefbf","fill-opacity":"0.18","label":true},"nodes":["f44dd0fb23b1a058","3b7c2e8aac54bd1a","82a46256fef4c8f5","e89fc6f5d7b6be61","aa6ab32c346b7dc2","c0220ac72c8668c7","dce0d347e9ad67cb","0108ed65d55f66e5","0df19651e9d47c89","1f2ae14226f8f2a4","2f6cacc4937ceef3","703af3c2779d3cf5"],"x":94,"y":379,"w":1612,"h":142},{"id":"60f0410cc18ffee9","type":"group","z":"d557eb264b53eeb0","name":"set NetAtmo credetials and start","style":{"fill":"#ffefbf","fill-opacity":"0.18","label":true},"nodes":["fb90035c5ef5b644","551f9e6651a9f547","68711059597f7ccf","58fbce5537d2f00e","cd7cdb17d57e2264","18e55452af6627a7"],"x":94,"y":59,"w":552,"h":162},{"id":"ef5434100e820b14","type":"group","z":"d557eb264b53eeb0","name":"single HTTP request","style":{"fill":"#ffefbf","fill-opacity":"0.18","label":true},"nodes":["60161afd811514a9","4a193c49e1768ca4","270c2571e554da91","477b057ce14583f1"],"x":104,"y":259,"w":482,"h":82},{"id":"a4f62c4a64ba8901","type":"group","z":"d557eb264b53eeb0","name":"error handling","style":{"fill":"#ffefbf","fill-opacity":"0.18","label":true},"nodes":["44d2edbb03e5abfd","0faeaea554fc754d","bbfc8353d57ad7ed","e38f7a66d5d55cbd","d4721fd3bb1730ab","0e4979ab14b36035"],"x":94,"y":919,"w":732,"h":122},{"id":"8f7287410467fd3f","type":"group","z":"d557eb264b53eeb0","name":"Test Input","style":{"fill":"#ffefbf","fill-opacity":"0.18","label":true},"nodes":["e541136a402b781c","1c0fa91ef5cd04aa"],"x":94,"y":1079,"w":432,"h":82},{"id":"f44dd0fb23b1a058","type":"inject","z":"d557eb264b53eeb0","g":"05a20f826b31f5bf","name":"refresh every 57 min","props":[{"p":"payload"}],"repeat":"3420","crontab":"","once":false,"onceDelay":"0","topic":"","payload":"","payloadType":"date","x":240,"y":440,"wires":[["1f2ae14226f8f2a4","0df19651e9d47c89"]]},{"id":"3b7c2e8aac54bd1a","type":"change","z":"d557eb264b53eeb0","g":"05a20f826b31f5bf","name":"Set param request & refresh","rules":[{"t":"set","p":"method","pt":"msg","to":"POST","tot":"str"},{"t":"set","p":"url","pt":"msg","to":"https://api.netatmo.com/oauth2/token","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"{\"grant_type\":\"refresh_token\",\"refresh_token\":$globalContext(\"NetatmoRefreshToken\"),\"client_id\":$globalContext(\"NetatmoClientId\"),\"client_secret\":$globalContext(\"NetatmoClientSecret\"),\"scope\": \"read_station\"}","tot":"jsonata"},{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers[\"content-type\"]","pt":"msg","to":"application/x-www-form-urlencoded","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":440,"wires":[["aa6ab32c346b7dc2"]]},{"id":"82a46256fef4c8f5","type":"change","z":"d557eb264b53eeb0","g":"05a20f826b31f5bf","name":"Store tokens & delay","rules":[{"t":"set","p":"NetatmoAccessToken","pt":"global","to":"payload.access_token","tot":"msg","dc":true},{"t":"set","p":"NetatmoRefreshToken","pt":"global","to":"payload.refresh_token","tot":"msg","dc":true},{"t":"set","p":"NetatmoLastUpdateTime","pt":"global","to":"","tot":"date"},{"t":"set","p":"payload","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":1380,"y":420,"wires":[["c0220ac72c8668c7"]]},{"id":"fb90035c5ef5b644","type":"change","z":"d557eb264b53eeb0","g":"60f0410cc18ffee9","name":"Set Netatmo Creds & Tokens","rules":[{"t":"set","p":"NetatmoClientId","pt":"global","to":"xxxxxxxxxxxxxxxxxxxxxxxxxx","tot":"str"},{"t":"set","p":"NetatmoClientSecret","pt":"global","to":"yyyyyyyyyyyyyyyyyyyyyyyyyyyy","tot":"str"},{"t":"set","p":"NetatmoAccessToken","pt":"global","to":"","tot":"str"},{"t":"set","p":"NetatmoRefreshToken","pt":"global","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":140,"wires":[[]]},{"id":"551f9e6651a9f547","type":"inject","z":"d557eb264b53eeb0","g":"60f0410cc18ffee9","name":"Set first credentials","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":230,"y":160,"wires":[["fb90035c5ef5b644","68711059597f7ccf"]]},{"id":"e89fc6f5d7b6be61","type":"switch","z":"d557eb264b53eeb0","g":"05a20f826b31f5bf","name":"access_token ok?","property":"payload","propertyType":"msg","rules":[{"t":"hask","v":"access_token","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1130,"y":440,"wires":[["82a46256fef4c8f5"],["0108ed65d55f66e5"]],"outputLabels":["Response OK","Error"]},{"id":"7737a67081eef4e8","type":"change","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"set pram request","rules":[{"t":"set","p":"payload","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"method","pt":"msg","to":"GET","tot":"str"},{"t":"set","p":"url","pt":"msg","to":"https://api.netatmo.com/api/getstationsdata","tot":"str"},{"t":"set","p":"headers","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"headers[\"Authorization\"]","pt":"msg","to":"\"Bearer \" & $globalContext(\"NetatmoAccessToken\")\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":720,"wires":[["400352be8a87340e"]]},{"id":"0443074dd4250d9c","type":"inject","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"Get Netatmo Data","props":[{"p":"payload"}],"repeat":"300","crontab":"","once":false,"onceDelay":"10","topic":"","payload":"","payloadType":"date","x":230,"y":720,"wires":[["df92a998996ce415"]]},{"id":"3a5362954f199d3f","type":"inject","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"Test","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":270,"y":760,"wires":[["df92a998996ce415"]]},{"id":"db5a4a411ed57be8","type":"switch","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"body?","property":"payload","propertyType":"msg","rules":[{"t":"hask","v":"body","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1090,"y":720,"wires":[["89225a8f357232c5","17d01814707624be","f1eec459e2893317","a1e6861787c7b9cd"],["a6600fbe65e81cc1"]]},{"id":"f1eec459e2893317","type":"mqtt out","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"Net_Atmo_record","topic":"Net_Atmo_record","qos":"0","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"99603ece.52e2a","x":1410,"y":720,"wires":[]},{"id":"17d01814707624be","type":"function","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"time / record counter","func":"let counter = context.get(\"counter\");\ncounter = counter + 1;\ncontext.set(\"counter\", counter);\n\nlet time = moment().tz(\"Europe/Berlin\").format(\"HH:mm:ss\");\nnode.status({ fill: \"green\", shape: \"dot\", text: time + \" / \" + counter });\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\n\ncontext.set(\"counter\", 0);\n","finalize":"","libs":[{"var":"moment","module":"moment"},{"var":"momentTimezone","module":"moment-timezone"}],"x":1420,"y":660,"wires":[[]]},{"id":"a1e6861787c7b9cd","type":"trigger","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"watchdog","op1":"","op2":"","op1type":"nul","op2type":"date","duration":"20","extend":true,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1380,"y":780,"wires":[["949e6679a2befee3"]]},{"id":"6b8ba085179f4f56","type":"link out","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"link out 258","mode":"link","links":["d4721fd3bb1730ab"],"x":1625,"y":780,"wires":[]},{"id":"949e6679a2befee3","type":"function","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"watchdog","func":"let text = \"NetAtmo-Record länger als 20 min offline!\";\nreturn { payload: { 'room': 'error', 'value': text } };","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1520,"y":780,"wires":[["6b8ba085179f4f56"]]},{"id":"89225a8f357232c5","type":"debug","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"status","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload.status","targetType":"msg","statusVal":"payload.status","statusType":"auto","x":1370,"y":600,"wires":[]},{"id":"12cb8cc73743c2ce","type":"switch","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"object?","property":"payload","propertyType":"msg","rules":[{"t":"istype","v":"object","vt":"object"},{"t":"istype","v":"string","vt":"string"}],"checkall":"true","repair":false,"outputs":2,"x":940,"y":720,"wires":[["db5a4a411ed57be8"],["74f8e9dde28cfcb1"]]},{"id":"60161afd811514a9","type":"http request","z":"d557eb264b53eeb0","g":"ef5434100e820b14","name":"","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":430,"y":300,"wires":[["270c2571e554da91"]]},{"id":"4a193c49e1768ca4","type":"link in","z":"d557eb264b53eeb0","g":"ef5434100e820b14","name":"netatmo_request_in","links":[],"x":145,"y":300,"wires":[["60161afd811514a9"]]},{"id":"270c2571e554da91","type":"link out","z":"d557eb264b53eeb0","g":"ef5434100e820b14","name":"link out 273","mode":"return","links":[],"x":545,"y":300,"wires":[]},{"id":"400352be8a87340e","type":"link call","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"call request 2","links":["4a193c49e1768ca4"],"linkType":"static","timeout":"30","x":770,"y":720,"wires":[["12cb8cc73743c2ce","3adc726ebd0aa92a"]]},{"id":"aa6ab32c346b7dc2","type":"link call","z":"d557eb264b53eeb0","g":"05a20f826b31f5bf","name":"call request 1","links":["4a193c49e1768ca4"],"linkType":"static","timeout":"30","x":850,"y":440,"wires":[["e89fc6f5d7b6be61","2f6cacc4937ceef3"]]},{"id":"44d2edbb03e5abfd","type":"catch","z":"d557eb264b53eeb0","g":"a4f62c4a64ba8901","name":"All errors","scope":["400352be8a87340e","aa6ab32c346b7dc2","60161afd811514a9","4a193c49e1768ca4","960cea8488046a64","3adc726ebd0aa92a"],"uncaught":false,"x":180,"y":1000,"wires":[["e38f7a66d5d55cbd"]]},{"id":"0faeaea554fc754d","type":"link out","z":"d557eb264b53eeb0","g":"a4f62c4a64ba8901","name":"link out 300","mode":"link","links":["d3422b90f8530fb4"],"x":635,"y":1000,"wires":[]},{"id":"bbfc8353d57ad7ed","type":"debug","z":"d557eb264b53eeb0","g":"a4f62c4a64ba8901","name":"debug  NetAtmo","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":700,"y":960,"wires":[]},{"id":"e38f7a66d5d55cbd","type":"function","z":"d557eb264b53eeb0","g":"a4f62c4a64ba8901","name":"Time + Fehlermeldung","func":"if (msg.payload.type === \"reset\"){\n    node.status({ fill: \"green\", shape: \"dot\", text: \" \" });\n    return null;\n}\n\nlet counter = context.get(\"counter\");\ncounter = counter + 1;\ncontext.set(\"counter\", counter);\n\nlet time = moment().tz(\"Europe/Berlin\").format(\"DD-MM-YYYY HH:mm:ss\");\n\nlet text = \"Fehlerzeitpunkt: \" + time + \" / \" +\n    \"RPI 45\" + \" / \" +\n    \"Flow: Netatmo New\" + \" / \" +\n    \"Fehlermeldung: \" + msg.error.message + \" / \" +\n    \"Fehler ID: \" + msg.error.source.id + \" / \" +\n    \"Fehlertyp: \" + msg.error.source.type + \" / \" +\n    \"Fehlernode: \" + msg.error.source.name + \" / \" +\n    \"Fehlerzähler: \" + msg.error.source.count;\n    \nnode.status({ fill: \"red\", shape: \"dot\", text: text + \" / \" + counter });\n\nreturn{payload:text};","outputs":1,"timeout":"","noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\nif (context.get(\"counter\") === undefined) {\n    context.set(\"counter\", 0);\n}","finalize":"","libs":[{"var":"moment","module":"moment"},{"var":"momentTimezone","module":"moment-timezone"}],"x":440,"y":1000,"wires":[["0faeaea554fc754d"]]},{"id":"d4721fd3bb1730ab","type":"link in","z":"d557eb264b53eeb0","g":"a4f62c4a64ba8901","name":"debug","links":["198aa8893d75f395","e0b35f90dd344f8f","6b8ba085179f4f56"],"x":525,"y":960,"wires":[["bbfc8353d57ad7ed","0faeaea554fc754d"]]},{"id":"0e4979ab14b36035","type":"inject","z":"d557eb264b53eeb0","g":"a4f62c4a64ba8901","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":"1","topic":"","payload":"{\"type\":\"reset\"}","payloadType":"json","x":220,"y":960,"wires":[["e38f7a66d5d55cbd"]]},{"id":"c0220ac72c8668c7","type":"debug","z":"d557eb264b53eeb0","g":"05a20f826b31f5bf","name":"refresh-count","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"","statusType":"counter","x":1570,"y":420,"wires":[]},{"id":"dce0d347e9ad67cb","type":"function","z":"d557eb264b53eeb0","g":"05a20f826b31f5bf","name":"Error no access token ","func":"node.error(\"Error Netatmo access token: \", msg);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1580,"y":480,"wires":[[]]},{"id":"0108ed65d55f66e5","type":"change","z":"d557eb264b53eeb0","g":"05a20f826b31f5bf","name":"set flow error true","rules":[{"t":"set","p":"error","pt":"flow","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1370,"y":480,"wires":[["dce0d347e9ad67cb"]]},{"id":"0df19651e9d47c89","type":"switch","z":"d557eb264b53eeb0","g":"05a20f826b31f5bf","name":"error?","property":"error","propertyType":"flow","rules":[{"t":"false"}],"checkall":"true","repair":false,"outputs":1,"x":450,"y":440,"wires":[["3b7c2e8aac54bd1a"]]},{"id":"68711059597f7ccf","type":"delay","z":"d557eb264b53eeb0","g":"60f0410cc18ffee9","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":460,"y":180,"wires":[["58fbce5537d2f00e"]]},{"id":"58fbce5537d2f00e","type":"link out","z":"d557eb264b53eeb0","g":"60f0410cc18ffee9","name":"link out 301","mode":"link","links":["7f0d116c40b05764"],"x":595,"y":180,"wires":[]},{"id":"a6600fbe65e81cc1","type":"function","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"Error body","func":"node.error(\"Netatmo no body Error: \", msg);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1390,"y":840,"wires":[[]]},{"id":"74f8e9dde28cfcb1","type":"function","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"Error object","func":"node.error(\"Netatmo no object Error: \", msg);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1190,"y":840,"wires":[[]]},{"id":"e541136a402b781c","type":"mqtt in","z":"d557eb264b53eeb0","g":"8f7287410467fd3f","name":"","topic":"Net_Atmo_record","qos":"0","datatype":"auto-detect","broker":"99603ece.52e2a","nl":false,"rap":true,"rh":0,"inputs":0,"x":200,"y":1120,"wires":[["1c0fa91ef5cd04aa"]]},{"id":"1c0fa91ef5cd04aa","type":"debug","z":"d557eb264b53eeb0","g":"8f7287410467fd3f","name":"netatmo record","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":400,"y":1120,"wires":[]},{"id":"df92a998996ce415","type":"switch","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"error?","property":"error","propertyType":"flow","rules":[{"t":"false"}],"checkall":"true","repair":false,"outputs":1,"x":430,"y":720,"wires":[["7737a67081eef4e8"]]},{"id":"1f2ae14226f8f2a4","type":"function","z":"d557eb264b53eeb0","g":"05a20f826b31f5bf","name":"next refresh at","func":"let t_end = Date.now() + 57 * 60 * 1000;\nlet x = new Date(t_end);\nlet text = x.toLocaleTimeString();\nnode.status({ fill: \"red\", shape: \"dot\", text: text });\nreturn null;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":480,"y":480,"wires":[[]]},{"id":"cd7cdb17d57e2264","type":"change","z":"d557eb264b53eeb0","g":"60f0410cc18ffee9","name":"","rules":[{"t":"set","p":"error","pt":"flow","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":460,"y":100,"wires":[[]]},{"id":"477b057ce14583f1","type":"change","z":"d557eb264b53eeb0","g":"ef5434100e820b14","name":"request timeout","rules":[{"t":"set","p":"requestTimeout","pt":"msg","to":"20000","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":300,"wires":[[]]},{"id":"18e55452af6627a7","type":"inject","z":"d557eb264b53eeb0","g":"60f0410cc18ffee9","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":210,"y":100,"wires":[["cd7cdb17d57e2264"]]},{"id":"3adc726ebd0aa92a","type":"switch","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"= 200?","property":"statusCode","propertyType":"msg","rules":[{"t":"neq","v":"200","vt":"str"},{"t":"eq","v":"200","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":830,"y":840,"wires":[["960cea8488046a64"],[]]},{"id":"960cea8488046a64","type":"function","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"Error != 200 2","func":"node.error(\"Statuscode != 200: \", msg);\nreturn null;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":980,"y":840,"wires":[[]]},{"id":"2f6cacc4937ceef3","type":"switch","z":"d557eb264b53eeb0","g":"05a20f826b31f5bf","name":"= 200?","property":"statusCode","propertyType":"msg","rules":[{"t":"neq","v":"200","vt":"str"},{"t":"eq","v":"200","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1010,"y":480,"wires":[["703af3c2779d3cf5"],[]]},{"id":"703af3c2779d3cf5","type":"function","z":"d557eb264b53eeb0","g":"05a20f826b31f5bf","name":"Error != 200 1","func":"node.error(\"Statuscode != 200: \", msg);\nreturn null;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1160,"y":480,"wires":[[]]},{"id":"7f0d116c40b05764","type":"link in","z":"d557eb264b53eeb0","g":"d508edfc10ca96d0","name":"link in 203","links":["58fbce5537d2f00e"],"x":305,"y":680,"wires":[["df92a998996ce415"]]},{"id":"99603ece.52e2a","type":"mqtt-broker","broker":"10.0.0.43","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":4,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","willTopic":"","willQos":"0","willPayload":""}]
Postman is not needed, that is the whole point of the oauth2 node, you can get the code automatically by number 3.
yes, I know.
Unfortunately I had some troubles with NetAtmo account due to too many requests - most probably
because I ran my application (potman) and oauth2in parallel. This took some time to fix it.
I am just working on integrating it into my flow.
I am taking the output of oauth2 and put it into my globals.
and run it with my flow.
btw - I found, that if you get your data every 5 min you should not have the refresh interval at a time that could be divided by 5. Lets say not 55 but 57min assuming both start a the same time.
I am not sure what you are saying. there is an authorisation part with a scope, for which you need to use a browser (oauth2 is really focussed on mobile which makes it so cumbersome), from which an access token is returned and a refresh token, which has an expiration time and needs to be refreshed ever so often to keep the validity of the access token (in case of netatmo it is 10800 seconds), while the token is valid you can query as much as the api allows.
Finaly it works and you are right!
This is the best solution!
Many thanks for your support :clap: :+1:
[{"id":"999dfdb30289d3e3","type":"tab","label":"NetAtmo Station Data","disabled":false,"info":"","env":[]},{"id":"5272032c77a66b98","type":"group","z":"999dfdb30289d3e3","name":"setup credentials","style":{"label":true,"fill":"#ffefbf","fill-opacity":"0.18"},"nodes":["6e08afb36e7f96f5","145a182f704b76ac","d2cc08c89ff1d00f","8c4a4fcc63ce3978","60d9f744b1e07999","f64122e6596886fc","05f984fb87660d8f","3d527fa8ed4c1cfa","60ae9a4aeb1d38e4"],"x":354,"y":179,"w":642,"h":142},{"id":"75782c100f960c0c","type":"group","z":"999dfdb30289d3e3","name":"","style":{"fill":"#ffefbf","fill-opacity":"0.18","label":true},"nodes":["aecdb575a82f1861","19ad1fa190620d37","1030561746bc5493","3452925d5ab99995","58283c72ded21f3a","e1d21a232577dec5","441df4bb7c2529c4","680d790b9a320732","99765cb02d0d44cd","0795e6725bcb0437","9192ea574d6e3ebe","afb5b58294ab7b9f","56523039f55483c3"],"x":354,"y":359,"w":1252,"h":322},{"id":"f8330cd67bea0c0a","type":"group","z":"999dfdb30289d3e3","name":"","style":{"fill":"#ffefbf","fill-opacity":"0.18","label":true},"nodes":["341c320f0b5b02a9","2d5c1a99a92ecf5f"],"x":354,"y":719,"w":432,"h":82},{"id":"aecdb575a82f1861","type":"inject","z":"999dfdb30289d3e3","g":"75782c100f960c0c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"300","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":470,"y":520,"wires":[["1030561746bc5493"]]},{"id":"19ad1fa190620d37","type":"http request","z":"999dfdb30289d3e3","g":"75782c100f960c0c","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":765,"y":520,"wires":[["9192ea574d6e3ebe"]],"l":false},{"id":"1030561746bc5493","type":"function","z":"999dfdb30289d3e3","g":"75782c100f960c0c","name":"get public data","func":"const access_token = global.get('netatmo_oauth2').token.access_token\n\nmsg.headers = {};\n\nmsg.headers[\"Authorization\"] = `Bearer ${access_token}`\n\nmsg.url = \"https://api.netatmo.com/api/getstationsdata\";\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":640,"y":520,"wires":[["19ad1fa190620d37"]]},{"id":"6e08afb36e7f96f5","type":"oauth2","z":"999dfdb30289d3e3","g":"5272032c77a66b98","name":"Authorization Code","container":"oauth2Response","grant_type":"authorization_code","access_token_url":"https://api.netatmo.com/oauth2/token","authorization_endpoint":"https://api.netatmo.com/oauth2/authorize","redirect_uri":"http://10.0.0.206:1880/oauth2/redirect","open_authentication":"","username":"","password":"","client_id":"","client_secret":"","response_type":"","access_type":"","refresh_token":"","prompt":"","scope":"read_station","resource":"","state":"","proxy":"","debug":false,"force":false,"senderr":false,"client_credentials_in_body":false,"rejectUnauthorized":true,"headers":{},"x":630,"y":220,"wires":[["f64122e6596886fc"]]},{"id":"145a182f704b76ac","type":"inject","z":"999dfdb30289d3e3","g":"5272032c77a66b98","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":460,"y":220,"wires":[["6e08afb36e7f96f5"]]},{"id":"d2cc08c89ff1d00f","type":"inject","z":"999dfdb30289d3e3","g":"5272032c77a66b98","name":"Refresh Token","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"3300","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":480,"y":280,"wires":[["3d527fa8ed4c1cfa"]]},{"id":"8c4a4fcc63ce3978","type":"oauth2","z":"999dfdb30289d3e3","g":"5272032c77a66b98","name":"Set by msg.oauth2Request","container":"oauth2Response","grant_type":"set_by_credentials","access_token_url":"http://localhost:3000/oauth/token ","authorization_endpoint":"","redirect_uri":"http://10.0.0.67:1880/oauth2/redirect","open_authentication":"","username":"","password":"","client_id":"","client_secret":"","response_type":"","access_type":"","refresh_token":"","prompt":"","scope":"*","resource":"","state":"","proxy":"","debug":true,"force":true,"senderr":false,"client_credentials_in_body":true,"rejectUnauthorized":true,"headers":{},"x":755,"y":280,"wires":[["60ae9a4aeb1d38e4"]],"l":false},{"id":"60d9f744b1e07999","type":"debug","z":"999dfdb30289d3e3","g":"5272032c77a66b98","name":"DBG 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":900,"y":280,"wires":[]},{"id":"f64122e6596886fc","type":"function","z":"999dfdb30289d3e3","g":"5272032c77a66b98","name":"Set refreshToken","func":"const access_token_url = \"https://api.netatmo.com/oauth2/token\"\n\nif (msg.oauth2Response.access_token) {\n    const netatmo_oauth2 = {}\n    netatmo_oauth2.url = access_token_url\n    netatmo_oauth2.token = msg.oauth2Response\n\n    global.set(\"netatmo_oauth2\", netatmo_oauth2)\n}\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":755,"y":220,"wires":[["05f984fb87660d8f"]],"l":false},{"id":"05f984fb87660d8f","type":"debug","z":"999dfdb30289d3e3","g":"5272032c77a66b98","name":"DBG 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":850,"y":220,"wires":[]},{"id":"3d527fa8ed4c1cfa","type":"function","z":"999dfdb30289d3e3","g":"5272032c77a66b98","name":"credentials","func":"let netatmo = global.get('netatmo_oauth2');\n\nmsg.oauth2Request = { \n    \"access_token_url\": netatmo.url,\n    \"credentials\": {\n        \"grant_type\": \"refresh_token\",\n        \"client_id\": \"\",\n        \"client_secret\": \"\",\n        \"scope\": \"read_station\",\n        \"refresh_token\": netatmo.token.refresh_token   \n    },\n};\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":650,"y":280,"wires":[["8c4a4fcc63ce3978"]]},{"id":"60ae9a4aeb1d38e4","type":"function","z":"999dfdb30289d3e3","g":"5272032c77a66b98","name":"Set refreshToken","func":"const access_token_url = \"https://api.netatmo.com/oauth2/token\"\n\nif (msg.oauth2Response.access_token) {\n    const netatmo_oauth2 = {}\n    netatmo_oauth2.url = access_token_url\n    netatmo_oauth2.token = msg.oauth2Response\n\n    global.set(\"netatmo_oauth2\", netatmo_oauth2)\n}\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":805,"y":280,"wires":[["60d9f744b1e07999"]],"l":false},{"id":"3452925d5ab99995","type":"switch","z":"999dfdb30289d3e3","g":"75782c100f960c0c","name":"body?","property":"payload","propertyType":"msg","rules":[{"t":"hask","v":"body","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1030,"y":520,"wires":[["0795e6725bcb0437","e1d21a232577dec5","58283c72ded21f3a","441df4bb7c2529c4"],["afb5b58294ab7b9f"]]},{"id":"58283c72ded21f3a","type":"mqtt out","z":"999dfdb30289d3e3","g":"75782c100f960c0c","name":"Net_Atmo_record","topic":"Net_Atmo_record","qos":"0","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"99603ece.52e2a","x":1350,"y":520,"wires":[]},{"id":"e1d21a232577dec5","type":"function","z":"999dfdb30289d3e3","g":"75782c100f960c0c","name":"time / record counter","func":"let counter = context.get(\"counter\");\ncounter = counter + 1;\ncontext.set(\"counter\", counter);\n\nlet time = moment().tz(\"Europe/Berlin\").format(\"HH:mm:ss\");\nnode.status({ fill: \"green\", shape: \"dot\", text: time + \" / \" + counter });\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\n\ncontext.set(\"counter\", 0);\n","finalize":"","libs":[{"var":"moment","module":"moment"},{"var":"momentTimezone","module":"moment-timezone"}],"x":1360,"y":460,"wires":[[]]},{"id":"441df4bb7c2529c4","type":"trigger","z":"999dfdb30289d3e3","g":"75782c100f960c0c","name":"watchdog","op1":"","op2":"","op1type":"nul","op2type":"date","duration":"20","extend":true,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1320,"y":580,"wires":[["99765cb02d0d44cd"]]},{"id":"680d790b9a320732","type":"link out","z":"999dfdb30289d3e3","g":"75782c100f960c0c","name":"link out 258","mode":"link","links":[],"x":1565,"y":580,"wires":[]},{"id":"99765cb02d0d44cd","type":"function","z":"999dfdb30289d3e3","g":"75782c100f960c0c","name":"watchdog","func":"let text = \"NetAtmo-Record länger als 20 min offline!\";\nreturn { payload: { 'room': 'error', 'value': text } };","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1460,"y":580,"wires":[["680d790b9a320732"]]},{"id":"0795e6725bcb0437","type":"debug","z":"999dfdb30289d3e3","g":"75782c100f960c0c","name":"status","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload.status","targetType":"msg","statusVal":"payload.status","statusType":"auto","x":1310,"y":400,"wires":[]},{"id":"9192ea574d6e3ebe","type":"switch","z":"999dfdb30289d3e3","g":"75782c100f960c0c","name":"object?","property":"payload","propertyType":"msg","rules":[{"t":"istype","v":"object","vt":"object"},{"t":"istype","v":"string","vt":"string"}],"checkall":"true","repair":false,"outputs":2,"x":880,"y":520,"wires":[["3452925d5ab99995"],["56523039f55483c3"]]},{"id":"afb5b58294ab7b9f","type":"function","z":"999dfdb30289d3e3","g":"75782c100f960c0c","name":"Error body","func":"node.error(\"Netatmo no body Error: \", msg);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1330,"y":640,"wires":[[]]},{"id":"56523039f55483c3","type":"function","z":"999dfdb30289d3e3","g":"75782c100f960c0c","name":"Error object","func":"node.error(\"Netatmo no object Error: \", msg);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1130,"y":640,"wires":[[]]},{"id":"341c320f0b5b02a9","type":"mqtt in","z":"999dfdb30289d3e3","g":"f8330cd67bea0c0a","name":"","topic":"Net_Atmo_record","qos":"0","datatype":"auto-detect","broker":"99603ece.52e2a","nl":false,"rap":true,"rh":0,"inputs":0,"x":460,"y":760,"wires":[["2d5c1a99a92ecf5f"]]},{"id":"2d5c1a99a92ecf5f","type":"debug","z":"999dfdb30289d3e3","g":"f8330cd67bea0c0a","name":"debug 2527","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":670,"y":760,"wires":[]},{"id":"99603ece.52e2a","type":"mqtt-broker","broker":"10.0.0.43","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":4,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","willTopic":"","willQos":"0","willPayload":""}]
