New Dashboard missing a much loved feature?
New Dashboard missing a much loved feature? How to show the row clicked? CSS to change the row background color for example?
Also, old Dashboard when row clicked resulting message included a row number which was handy as a reference, so for any Array of 'off' screen data, where the table only showed a subset of said data. Yeah, I can add a function node to find the row in the array via findIndex() for example but having table provide it was quite elegant.
Google A.I., yeah I know... but figured maybe? Come back with this example... it does one thing... deletes the row you click on! LOL How much of this do I understand? Ah... I at least got the UI Table id right... because the table changed on row click [cough].
<style>
.highlighted-row {
    background-color: #e0e0e0 !important;
    color: black !important;
    font-weight: bold;
</style>
<script>(function(scope) {
    scope.$watch('msg.eb49cd13304dcf6d', function(msg) {
        if (msg && msg.payload) {
            // Remove existing highlight from all rows
            const allRows=document.querySelectorAll('.v-data-table__wrapper tbody tr');
            allRows.forEach(row=> {
                row.classList.remove('highlighted-row');
            // Iterate over the rows and find the one matching the clicked data
                // This is a generic way to check if row data matches the clicked data.
                // You might need a specific unique identifier (e.g., ID column)
                // for a more robust solution, but this often works.
                let rowDataMatch=true;
                const cells=row.querySelectorAll('td');
                const clickedDataKeys=Object.keys(msg.payload);
                if (cells.length===clickedDataKeys.length) {
                    for (let i=0; i < cells.length; i++) {
                        const key=clickedDataKeys[i];
                        if (cells[i].innerText !=msg.payload[key]) {
                            rowDataMatch=false;
                            break;
                else {
                    // Fallback for potential column mismatch or complex data types
                    // Maybe check a specific key if available
                    // console.log("Column count mismatch, trying less robust check");
                    try {
                            if(row.innerText.includes(msg.payload[clickedDataKeys[0]])) {
                                rowDataMatch=true;
                            else {
                                rowDataMatch=false;
                        catch (e) {
                    if (rowDataMatch) {
                        row.classList.add('highlighted-row');
    })(scope);
</script>
I haven't used the table much, but if you want more sophisticated features then others have recommended node-red-dashboard-2-table-tabulator (node) - Node-RED.
Oh... will give that shot
I'm here if you need help for this
@Colin, Yes! You, and this forum is always helpful... frankly one of the best forums I have ever used... and I have leveraged many forums, even discord servers.
Actually that was @omrid offering help if you decided to try his tabulator node.
Oops! Well the comment is still true!
Grateful to be here…Appreciation Post
Thanks for being the friendliest forum around!
Just want to say a massive thank you to everyone on this forum
The Best Forum you will come across. I visit here everyday.
