New minute event
Could anyone recommend a node which will give me a new minute event. I do not want to use a inject node with 1m repeat but rather i require the event to be triggered based on the clock every new minute. I currently do not have any scheduling nodes in my flow so am looking for suggestions based on your experience.
D
Cron plus will do this no problem. It has a ton more features that may also be useful to you.
Also, I am fairly sure this is the only node that will self correct if the system clock adjusts (due to time sync or manual adjustment) further guaranteeing it will hit that minute mark.
Doesn't this setting in the inject node work for you?
inject
But, as @Steve-Mcl has already recommended - I usually use Cron Plus for most timing events.
perfect, thank you for your help. Cron Plus it is.
