Nicht mehr als 2 Motoren einschalten
Hallo
ich versuche ein Programm zu schreiben, indem es 4 Motoren gibt, aber es sollen sich maximal 2 gleichzeitig einschalten lassen.
aber es wird IMMER "false" ausgegeben
// Code in der Funktion
var x0 = {payload: msg.payload.x0};
var x1 = {payload: msg.payload.x1};
var x2 = {payload: msg.payload.x2};
var x3 = {payload: msg.payload.x3};
var msg1={};
if (!x3 && x2 && x1 && x0 || x3 && !x2 && x1 && x0 || x3 && x2 && !x1 && x0 || x3 && x2 && x1 && x0 || x3 && x2 && x1 && x0){
msg1.payload = "false";
else{
msg1.payload = "true";
return msg1;
bitte helft mir
LG
var x0 = msg.payload.x0;
var x1 = msg.payload.x1;
var x2 = msg.payload.x2;
var x3 = msg.payload.x3;
That's what I think could be it, without knowing what is coming into the function.
if the state of the motors is coming in multiple msg's, then you need to safe the state into context or flow variable to keep track of them.
a quick flow example;
[{"id":"a00a0735.0eb5b8","type":"inject","z":"95f61204.15452","name":"","topic":"motor1","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":262,"y":1368,"wires":[["d4c5a420.9a8e58"]]},{"id":"8d59f29f.ad995","type":"inject","z":"95f61204.15452","name":"","topic":"motor1","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":262,"y":1404,"wires":[["d4c5a420.9a8e58"]]},{"id":"633095bd.8216dc","type":"inject","z":"95f61204.15452","name":"","topic":"motor2","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":262,"y":1464,"wires":[["d4c5a420.9a8e58"]]},{"id":"6b321c7b.908b44","type":"inject","z":"95f61204.15452","name":"","topic":"motor2","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":262,"y":1500,"wires":[["d4c5a420.9a8e58"]]},{"id":"1642c43d.6a50fc","type":"inject","z":"95f61204.15452","name":"","topic":"motor3","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":262,"y":1560,"wires":[["d4c5a420.9a8e58"]]},{"id":"9bd997cd.b708c8","type":"inject","z":"95f61204.15452","name":"","topic":"motor3","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":262,"y":1596,"wires":[["d4c5a420.9a8e58"]]},{"id":"422559a0.3a73a8","type":"inject","z":"95f61204.15452","name":"","topic":"motor4","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":262,"y":1656,"wires":[["d4c5a420.9a8e58"]]},{"id":"59321b02.444154","type":"inject","z":"95f61204.15452","name":"","topic":"motor4","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":262,"y":1692,"wires":[["d4c5a420.9a8e58"]]},{"id":"d4c5a420.9a8e58","type":"function","z":"95f61204.15452","name":"","func":"var nr = parseInt(msg.topic.substring(msg.topic.length - 1))-1;\nvar count = 0;\ncontext.set(\"state[\" + nr +\"]\", msg.payload);\n\nfor (var i in context.get(\"state\")){\n    \n    if (context.get(\"state[\" + i +\"]\") === true ) {\n        count++\n    }\n    msg.payload = count < 3?\"oke\":\"to Match\";\n}\nreturn msg;","outputs":1,"noerr":0,"x":542,"y":1536,"wires":[["33fbaaa3.d24036"]]},{"id":"33fbaaa3.d24036","type":"debug","z":"95f61204.15452","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":674,"y":1536,"wires":[]}]
temp
