I suggested using a change node - but as you already have a function node then in there may well be easiest. I would move hardware_serial to name and latitude to lat etc.
Im sure i didnt got you explanation right, what node should i edit? I dont see any hardware_serial and so on..
That came from your original message.... so I assumed you had that in your function node...
Thanks for the reply, i have a small succesful update that the map is working, i used your suggestion and used instead a change node with an inject button on the back and then to the map. Used the following object as a JSON in change {"name":"Joe", "lat":41.1613, "lon":24.1386} and i get my point on the map manually. Question is how i will feed the same off the ttn_uplink using a path copy of my lon and lat in the same brackets and the type of the syntax. Just for reference
payload_fields: object
altitude: "159.9m"
barometer: "989.7hPa"
battery: "3.79V"
gasResistance: "11.83KΩ"
humidity: "57%RH"
latitude: "41.1612°"
longitude: "24.1387°"
temperature: "22.3°C"
and if i copythe path i get this "payload_fields.latitude"
tried different syntax respect to
{ "name":"Jason", "lat":51.05, "lon":-1.35 } but nothing
So you have msg.payload object like
altitude: "159.9m"
battery: "3.79V"
humidity: "57%RH"
so you need to ffed this to a change node that is set to
move [msg.]payload.latitude to [msg.]payload.lat
move [msg.]payload.longitude to [msg.]payload.lon
set [msg.]payload.name to [string]Some_name_of_your-Choice
then feed it into the worldmap
Look at what I typed. Move not set
Thanks for the clarification, im not very proficient in this.
How will it parse the actual data im curious with that.
As there is nothing in the recent object that you shared that could be a name just SET msg.payload.name to a string of some words of your choice
Here is a simple example flow to show you - based on your payload above.
[{"id":"434f2d44.298a94","type":"inject","z":"8df32294.80f4f","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":260,"wires":[["fe0977bb.728668"]]},{"id":"fe0977bb.728668","type":"function","z":"8df32294.80f4f","name":"create dummy input","func":"msg.payload = { \n altitude: \"159.9m\",\n barometer: \"989.7hPa\",\n battery: \"3.79V\",\n gasResistance: \"11.83KΩ\",\n humidity: \"57%RH\",\n latitude: \"41.1612\",\n longitude: \"24.1387\",\n temperature: \"22.3°C\",\n}\nreturn msg;","outputs":1,"noerr":0,"x":330,"y":260,"wires":[["42512ca5.9631c4"]]},{"id":"42512ca5.9631c4","type":"change","z":"8df32294.80f4f","name":"","rules":[{"t":"set","p":"payload.name","pt":"msg","to":"My_Super_Device","tot":"str"},{"t":"move","p":"payload.latitude","pt":"msg","to":"payload.lat","tot":"msg"},{"t":"move","p":"payload.longitude","pt":"msg","to":"payload.lon","tot":"msg"},{"t":"set","p":"payload.altitude","pt":"msg","to":"payload.alt","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":320,"wires":[["43e3cbe8.307ee4","688913c4.7d992c"]]},{"id":"43e3cbe8.307ee4","type":"worldmap","z":"8df32294.80f4f","name":"","lat":"","lon":"","zoom":"13","layer":"","cluster":"","maxage":"","usermenu":"show","layers":"show","panit":"true","panlock":"false","zoomlock":"false","hiderightclick":"false","coords":"none","showgrid":"false","path":"/worldmap","x":560,"y":320,"wires":[]},{"id":"688913c4.7d992c","type":"debug","z":"8df32294.80f4f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":570,"y":380,"wires":[]}]
I loaded it, it works with a click, now i have either find a way to write some code in the function node to parse the data from ttn_uplink or some solution with the change node ( i think it need some kind of conversion of the path were the data is to a JSON accepted format)
Yes - if you actually show us what comes out of a debug node attached to your TTN feed we may be able to help - Or we could try mind reading.
i also tried to change the coding from TTN to Cayene LPP and added to the change node as JSON {"name":"Joe", "lat":payload.gps_1.latitude, "lon":payload.gps_1.longitude} but its not valid hence no data to the map
@dceejay dceejay, i finally made it work. i get my location on the map. i used the function node and edited a script i found online. it still gives invalid JSON property but it works.
var msg1 = {
"payload" : JSON.parse(JSON.stringify(data))
return msg1;
In your picture above you linked the TTN node to the dummy data node... it should go direct to the change node as it already has the data...
@dceejay Yes that purpose was only for you see the payload example in the debug window, thanks though!
It worked as i altered the decode function in TTN and edited the fuction script within the function.
