System: Raspberry Pi 4 with 4Gb Ram
New image Bullseye 32bits
latest update
Install Node-red using scrip from nodered.org site
This can take 20-30 minutes on the slower Pi versions - please wait.
Stop Node-RED ✔
Remove old version of Node-RED ✔
Remove old version of Node.js ✔
Install Node 20.19.0-1nodesource1 ✔ v20.19.0 Npm 10.8.2
Clean npm cache ✔
Install Node-RED core ✔ 4.0.9
Move global nodes to local -
Npm rebuild existing nodes ✔
Install extra Pi nodes -
Add shortcut commands ✔
Update systemd script ✔
log
Any errors will be logged to /var/log/nodered-install.log
Starting as a systemd service.
1 Apr 10:58:17 - [info]
Welcome to Node-RED
1 Apr 10:58:17 - [info] Node-RED version: v4.0.9
1 Apr 10:58:17 - [info] Node.js version: v20.19.0
1 Apr 10:58:17 - [info] Linux 6.1.21-v8+ arm LE
1 Apr 10:58:17 - [info] Loading palette nodes
1 Apr 10:58:19 - [info] Settings file : /home/pi/.node-red/settings.js
1 Apr 10:58:19 - [info] Context store : 'default' [module=memory]
1 Apr 10:58:19 - [info] User directory : /home/pi/.node-red
1 Apr 10:58:19 - [warn] Projects disabled : editorTheme.projects.enabled=false
1 Apr 10:58:19 - [info] Flows file : /home/pi/.node-red/flows.json
1 Apr 10:58:19 - [info] Creating new flow file
1 Apr 10:58:19 - [warn] Encrypted credentials not found
1 Apr 10:58:19 - [info] Server now running at http://127.0.0.1:1880/
1 Apr 10:58:19 - [info] Starting flows
1 Apr 10:58:19 - [info] Started flows
1 Apr 11:00:15 - [info] Installing module: node-red-dashboard, version: 3.6.5
1 Apr 11:00:31 - [info] Installed module: node-red-dashboard
1 Apr 11:00:32 - [info] Dashboard version 3.6.5 started at /ui
1 Apr 11:00:32 - [info] Added node types:
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_base
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_button
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_dropdown
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_switch
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_slider
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_numeric
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_text_input
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_date_picker
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_colour_picker
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_form
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_gauge
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_chart
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_audio
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_toast
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_ui_control
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_template
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_link
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_tab
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_group
1 Apr 11:00:32 - [info] - node-red-dashboard:ui_spacer
1 Apr 11:00:47 - [info] Installing module: node-red-node-email, version: 3.0.3
1 Apr 11:00:54 - [info] Installed module: node-red-node-email
1 Apr 11:00:55 - [info] Added node types:
1 Apr 11:00:55 - [info] - node-red-node-email:e-mail
1 Apr 11:00:55 - [info] - node-red-node-email:e-mail in
1 Apr 11:00:55 - [info] - node-red-node-email:e-mail mta
1 Apr 11:01:38 - [info] Stopping flows
1 Apr 11:01:38 - [info] Stopped flows
1 Apr 11:01:38 - [info] Updated flows
1 Apr 11:01:38 - [info] Starting flows
Using same account from my ISP
for email-send and email-in
Node email-send send failed with catch node error message
Error messsage:
Error: Connection closed unexpectedly
at SMTPConnection._onClose (/home/pi/.node-red/node_modules/node-red-node-email/node_modules/nodemailer/lib/smtp-connection/index.js:861:34)
at SMTPConnection._onSocketClose (/home/pi/.node-red/node_modules/node-red-node-email/node_modules/nodemailer/lib/smtp-connection/index.js:197:42)
at Object.onceWrapper (node:events:639:26)
at TLSSocket.emit (node:events:536:35)
at node:net:343:12
at TCP.done (node:_tls_wrap:648:7)
Node email-in
Checkbox Start TLS = never
Works fine
From Bullseye desktop
Installed Claws mail (recommended software)
Setup my account
Send and receive mail function works fine with my ISP
This was running Ok on very old version Node-red 1.x
How can I fix the node email-send ?
thanks for your help
