Node-js with Redis
var redis = context.global.get('redis');
client = redis.createClient(6379,'localhost');
var test=client.hget('hash key','hashtest 1', function(err, results) {
if (err) {
} else {
// do something with results
console.log(results);
client.quit();
console.log("Value=="+test);
msg.payload={"Value":test};
When I am executing this code ,I am getting this output ,
Value==false
{"Value":false}
Please help me out.
Thank you.
If you share code, please format it properly using ```
Your Redis request returns the data in a callback function, so that part runs asynchronously and gets executed after your log output. You need to send the data inside your callback function using node.send(msg). Have a look at the docs under "Sending messages asynchronously".
I would consider using one of the existing Redis nodes found here. That makes it a lot easier than doing this in a function node.
NOTE: I would recommend this one, I have been using it myself for some time now.
Thanks a lot, the issue got solved.
Given the multiple threads you started where was the issue solved?
Then the thread becomes useful to other users in the future
This thread issue was solved .
Where? How?
What was the answer?
Make this thread useful to others finding it in the future
client.hget('0000f8f005f1','OutBound', function(err, results) {
    if (err) {
       console.log(err);
    } else {
       client.quit();
       node.send({payload:results});
'0000f8f005f1' what is this value in this code?
Its the key
Maybe look at the redis docs ?
https://redis.io/commands/hget
Hello @dceejay i need to fetch the data from redis in node-red, can you help me out with this?
@Iliyas please use the topic you have already started - Fetching data from redis database
@Iliyas please stop posting to this topic. Use the separate one you have started.
