Node library conflict variables on html file
Hi!
I reelected the following problem in Node-Red 3.0.2 Node v18,
I developed three similar libraries (circumstances made it necessary for them to be three libraries)
we detected in these libraries upon installation of at least two of them in a Node-Red impanto that some nodes were adding to overwrite themselves,
I verified:
  • the registration are different
  • the assignment in the “packege.json” are different
  • the file names are different
after a few hours of debugging I found the cause of the problem it seems that the nodes in their html file encoded in the script part of the variables with the same name,
immagine
once replaced in all of them there was no more conflict/overwriting in installation,
i think it is deeply related to the operation of JQuery in loading the node html
since it is very likely to happen in the future.
is it possible to foresee a bug fix at core level?
Hi @APXc
Can you share some more details? Is the source code available anywhere for us to have a look? If not, can you try recreating it with a simple example?
At this point, we don't have enough details to understand the issue.
Nick
Hi @knolleary,
this is a original code on html file before fix
the name variables it's:
  • servicesName
  • servicesData
library 1
  let servicesName = [];
  let servicesData = {};
    $.getJSON('services', (data, status) => {
      for(service in data) {
        servicesData = data;
        servicesName.push(service);
  RED.nodes.registerType('serviceSap',{
    category: 'Sap',
    color: '#FFC300',
    defaults: {
      serviceName: {value: ''},
      service: {value: ''},
      // entity: {value: ''},
      // udo: {value: ''},
      // udt: {value: ''},
      // entityId: {value: ''},
      // docEntry: {value: ''},
      // code: {value: ''},
      headers: {value: ''},
      bodyPost: {value: ''}
    inputs:1,
    outputs:1,
    icon: 'font-awesome/fa-gears',
    label: function() {
      return this.name||"Sap service";
    oneditprepare: function() {
      // $("#node-input-entityId").typedInput({
      //   type:"msg",
      //   types:["msg"],
      //   typeField: "#node-input-entityId-type",
      //   value: 'entityId'
      // $("#node-input-docEntry").typedInput({
      //   type:"msg",
      //   types:["msg"],
      //   typeField: "#node-input-docEntry-type",
      //   value: 'docEntry'
      // $("#node-input-code").typedInput({
      //   type:"msg",
      //   types:["msg"],
      //   typeField: "#node-input-code-type",
      //   value: 'code'
      $("#node-input-headers").typedInput({
        type:"msg",
        types:["msg"],
        typeField: "#node-input-headers-type",
        value: 'headers'
      $("#node-input-bodyPost").typedInput({
        type:"msg",
        types:["msg"],
        typeField: "#node-input-bodyPost-type",
        value: 'bodyPost'
      // jQuery("#node-input-entity").change(function() {
      //   jQuery('#container-udo').hide();
      //   jQuery('#container-docEntry').hide();
      //   jQuery('#container-udt').hide();
      //   jQuery('#container-code').hide();
      //   jQuery('#container-entityId').hide();
      //   if (jQuery(this).val() === 'UDO'){
      //     jQuery('#container-udo').show();
      //     jQuery('#container-docEntry').show();
      //   if (jQuery(this).val() === 'UDT'){
      //     jQuery('#container-udt').show();
      //     jQuery('#container-code').show();
      //   if(jQuery(this).val() !== 'UDO' && jQuery(this).val() !== 'UDT') {
      //     jQuery('#container-entityId').show();
      servicesName.forEach((service) => {
        $('#node-input-serviceName')
          .append($("<option></option>")
                      .attr("value", service)
                      .text(service));
      // set the previous value
      if(this.serviceName) {
        $('#node-input-serviceName').val(this.serviceName);
      $("#node-input-serviceName").change((event) => {
        const service = $("#node-input-serviceName").val();
        $('#node-input-service').empty();
        if(servicesData[service]) {
          servicesData[service].forEach((endpoint) => {
                        .attr("value", endpoint)
                        .text(endpoint));
          // trick check if change with click or not
          if(!event.originalEvent){
            $('#node-input-service').val(this.service);
</script>
<script type="text/html" data-template-name="serviceSap">
  <div class="form-row">
    <label for="node-input-name"><i class="fa fa-tag"></i> Name</label>
    <input type="text" id="node-input-name" placeholder="Name">
  </div>
    <label for="node-input-type"><i class="fa fa-gears"></i> Service</label>
    <select name="node-input-serviceName" id="node-input-serviceName">
      <option></option>
    </select>
  </div>
    <label for="node-input-type"><i class="fa fa-gears"></i> Endpoint</label>
    <select name="node-input-service" id="node-input-service">
    </select>
  </div>
    <label for="node-input-type"><i class="fa fa-cog"></i> Headers</label>
    <input type="text" id="node-input-headers">
    <input type="hidden" id="node-input-headers-type">
  </div>
    <label for="node-input-type"><i class="fa fa-cog"></i> BodyPost</label>
    <input type="text" id="node-input-bodyPost">
    <input type="hidden" id="node-input-bodyPost-type">
  </div>
</script>
<!-- Documentation -->
<script type="text/html" data-help-name="serviceSap">
  <p>Post action</p>
  <h3>Inputs</h3>
      <dl class="message-properties">
          <dt>Name
            <span class="property-type">string</span>
          </dt>
          <dd> the node's name </dd>
          <dt>Entity
          </dt>
          <dd> the entity name of SAP </dd>
          <dt>entityId
            <span class="property-type">number | string</span>
          </dt>
          <dd> the id of the entity of SAP </dd>
          <dt>bodyPost
            <span class="property-type">object</span>
          </dt>
          <dd> data to update to the entity </dd>
      </dl>
   <h3>Outputs</h3>
       <ol class="node-ports">
           <li>Standard output
                   <dt>payload <span class="property-type">string</span></dt>
                   <dd>the standard output of the command.</dd>
               </dl>
           </li>
       </ol>
  <h3>Details</h3>
      <p>this node is used to update the entity of SAP.
        See the examples to understand how to use it.
      </p>
      <!-- <p><code>msg.payload</code> is used as the payload of the published message.
      If it contains an Object it will be converted to a JSON string before being sent.
      If it contains a binary Buffer the message will be published as-is.</p>
      <p>The topic used can be configured in the node or, if left blank, can be set
      by <code>msg.topic</code>.</p>
      <p>Likewise the QoS and retain values can be configured in the node or, if left
      blank, set by <code>msg.qos</code> and <code>msg.retain</code> respectively.</p> -->
</script>
library 2
  RED.nodes.registerType('serviceLayerOneSL',{
    category: 'LayerOne SL',
    color: '#139ce9',
    defaults: {
    inputs:1,
    outputs:1,
    label: function() {
      //   type:"msg",
      //   types:["msg"],
      //   type:"msg",
      //   types:["msg"],
      //   type:"msg",
      //   types:["msg"],
      //   value: 'code'
        type:"msg",
        types:["msg"],
        value: 'headers'
        type:"msg",
        types:["msg"],
        value: 'bodyPost'
                      .text(service));
                        .text(endpoint));
</script>
<script type="text/html" data-template-name="serviceLayerOneSL">
  </div>
      <option></option>
    </select>
  </div>
    </select>
  </div>
  </div>
  </div>
</script>
<script type="text/html" data-help-name="serviceLayerOneSL">
  <p>Post action</p>
  <h3>Inputs</h3>
          <dt>Name
          </dt>
          <dt>Entity
          </dt>
          <dt>entityId
          </dt>
          <dt>bodyPost
          </dt>
      </dl>
   <h3>Outputs</h3>
           <li>Standard output
               </dl>
           </li>
       </ol>
  <h3>Details</h3>
      </p>
</script>
library 3
  RED.nodes.registerType('you-layerone2-sl-service',{
    category: 'LayerOne2SL',
    color:"#139ce9",
    defaults: {
    inputs:1,
    outputs:1,
    paletteLabel: "Service",
    label: function() {
        type:"msg",
        types:["msg"],
        value: 'headers'
        type:"msg",
        types:["msg"],
        value: 'bodyPost'
                      .text(service));
                        .text(endpoint));
</script>
<script type="text/html" data-template-name="you-layerone2-sl-service">
  </div>
      <option></option>
    </select>
  </div>
    </select>
  </div>
  </div>
  </div>
</script>
<script type="text/html" data-help-name="you-layerone2-sl-service">
  <p>Post action</p>
  <h3>Inputs</h3>
          <dt>Name
          </dt>
          <dt>Entity
          </dt>
          <dt>entityId
          </dt>
          <dt>bodyPost
          </dt>
      </dl>
   <h3>Outputs</h3>
           <li>Standard output
               </dl>
           </li>
       </ol>
  <h3>Details</h3>
      </p>
</script>
All three of those are adding servicesName and servicesData to the global scope - so they will overwrite each other.
One solution is to wrap your code in a function:
;(function () {
This will keep those variables scoped to your node.
Yes, this is something I discovered early on and is easily overlooked by new entrants to node development.
Code isolation is quite a tricky concept in relation to Node-RED due to it loading so many different modules.
