Just mentioning here.
I recently installed a node from the big library.
It is a "LOGGER".
Yet, when I click on the node with INFO this is what I see:
A simple node that converts the message payloads into all lower-case characters
Seems a bit in congruent.
              But the functionality of the node is there?
i.e. it’s just the text that needs updating?
If so you should open an issue on the nodes github page as the author isn’t guaranteed to read this.
You can find a link to the nodes github page from the nodes info on flows.nodered.org
              Ok, sorry.
But I just wanted to share what I saw.
Shall follow up with the other post later.    Stuck on another problem just now.
