Node-RED 1.0.5 has been released with the usual small collection of fixes across the board.
Full details here: https://github.com/node-red/node-red/releases/tag/1.0.5
Hi Nick (@knolleary) ,
Thanks for this new release!
It seems there is - in particular cases - an issue with the pimped TypedInput fields.
In our ui-svg node we create a table with typedinputs, but some labels appear below the TypedInput fields (but it is solved as soon as we make the config screen a bit wider):
There isn't anything weird in the console log.
If you need other information, please let me know!
Thanks!
Bart
Thanks Bart.
I've pushed a fix for 1.0.6 which we can do early next week (pending any other issues that crop up)
Nick
I have similar case but for custom type definitions where label is string
var typedefinitions = {
min: {
value: "min",
label: "Min ",
validate: RED.validators.number()
max: {
value: "max",
label: "Max ",
sec: {
value: "sec",
label: "Sec ",
And outcome is cropped currently
If already covered by fix, please ignore.
