Node-RED 2.1.2 is now available.
This has resolved the outstanding issues with the TypedInput widget - but do let us know if you see anything odd.
There is still an issue with TypedInput: If you put anything in the Class field it is not retained when you close the Edit text input node dialog.
@zenofmud has a fix for this.
What class field? Is this a particular node?
@jbudd are referring to the ui-text-input on dashboard? I'm helping Paul out on DM (has nothing to do with typedInput)
I have seen the issue you are referring to - that is nothing to do with the TypedInout widget.
The fix for that will come via the dashboard node module, not the core.
Oh OK, confused by the similar names!
