I forgot the login - how can I reset it.
regards Erwin
regards Erwin
Hi @Nilpferd
Assuming this is a regular local install of Node-RED, then you should have a settings.js file that includes your login details. The password will be hashed, so you'll need to generate a new password hash and update the file, then restart Node-RED to pickup the change.
Node-RED logs the full path to the settings file when it starts up. By default it is under a directory called .node-red in your user's home directory.
https://nodered.org/docs/user-guide/runtime/securing-node-red#usernamepassword-based-authentication
Thanks, but in this case it will be quicker to reinstall NR.
Reinstalling node red will not do it.
And then setup security again from scratch that involves more steps then just updating the password in your existing setup? I don't think that'll be quicker.
