Node Red as a "Service" on Windows 10 Lenovo PC
As of now I manually start "PowerShell" and then Node-Red. I'm wanting to run both as a Windows Service can this be done? Is there a better way?
Hi @damica51
You wouldn't run powershell as the service, to start Node RED, instead, you configure Node RED as a service.
The tool to use is NSSM.
see here: Running Node-RED as a service on Windows using NSSM · GitHub
Thanks, I will read so that I understand before I do anything.
