Run on windows as service
I have created a node-red application that works together with an Opto 22 controller to monitor alarms. I installed the app on the computer used on the company where it is going to be working. But sometimes operators close the command prompt where the node-red is running and the app stops.
Is there a way to run node red as a windows service?. In that way as the computer is turned on, node red would be instantiated.
Yes.
Running Node-RED as a service on Windows using NSSM ...
Running Node Red in Windows - General - Node-RED Forum
Running on windows server 2012 r2 - General - Node-RED ...
https://nodered.org/docs/faq/starting-node-red-on-boot
Starting Node-RED on boot : Node-RED
