When I try to register my device to Azure IOT Hub using the 'Azure IOT Hub Registry' Block, I get the following error message:
Error while trying to create a new device: UnauthorizedError: Unauthorized
My inject node has the correct jason format as:
{"deviceId":"TestDevice"}
The 'Azure IOT Hub Registry Node" has the connection string of the IOT Hub.
Has anyone encountered the same problem recently?
