Hi there,
I have node-red-contrib-alexa-notifyme in node-red installed and I got api-key and api-secret.
In the node I have to type the Access Code. I typed in the api-key --> fault, I typed in the api-key:api-secret --> fault.
Does anybody know what there is required in the Access Code - field?
Thanks in advance
Martin
Just discovered there are two notifyme skills Alexa skills so ignore my previous deleted info
Just tried it with browser and that works
https://api.notifymyecho.com/v1/NotifyMe?notification=Hello%20World!&accessCode=nmac.P69.....rest of access code
[Edit]Works for me - I think you've done the same as I did and installed the wrong NotfyMe skill as that has two codes but the Thomptronics one (which is whats needed for this) only has one code
So remove existing skill and add in the correct one and all should be good
Hours later, I got it, thanks to claude.
Via inject-node send msg.payload as text to a function node.
Content of function node:
msg.payload = { message: msg.payload };
http request node:
That's it.
user: api-key
passw.: api-secret
