Node-red-contrib-balered
node-red-contrib-balered was release. BaleRed helps you to send and receive message through Bale Messenger (www.bale.ai).
Provided nodes helps you to send and receive any kind of messages, and nodes are made if a way that makes using Bale Bots as easy as possible.
The source code can be accessed in https://github.com/M-Ahadi/BaleRed
why this node has not been published in nodered website?
knolleary
Because it has not been published with node-red as one of its keywords in package.json. You have node red is it incorrect.
thank you so much for your help
