Node-red-contrib-fanuc-focas does not reconnect
Title: node-red-contrib-fanuc-focas 0.0.2 – does not reconnect after CNC power-cycle, only a Node-RED restart fixes it
Hi all,
I'm using node-red-contrib-fanuc-focas 0.0.2 to read FANUC CNCs over FOCAS2 (polling every ~15 s).
Problem: when a CNC is powered off and then back on, the node never reconnects. It keeps logging "Open handshake failed". Restarting Node-RED fixes it right away.
Setup: Node-RED [5.0.0], Node.js [V22], [Ubuntu]
What I tried:
  • The CNC is reachable after power-up: no
  • Redeploying the flow: does not fix it
  • Full Node-RED restart: fixes it
Is this a known issue in 0.0.2? Is there a way to make it reconnect without restarting Node-RED?
Thanks!
I see the issue has been reported as an issue on the nodes GitHub page but the author has unfortunately not responded. You could add a comment there in the hope that you get a response.
Alternatively, you could try this project to collect your data:
We use it to connect with about 25 Fanuc PLCs. Works flawlessly.
The data gets published via MQTT for further processing in a Node-RED instance.
