Node-red-contrib-fcm-push-node
Hi.
Is this node working? I cannot send notifications and I get no error messages. I have tried both Server Key and Sender ID as FCM_SERVER_KEY environment variable. I use "to": "FCM registration token", which works when I send notifications from Firebase. I inject a msg.payload as JSON:
"notification": {
"title": "My title",
"body": "My body"
I am gratefful if anyone using this node successfully will give me some advice.
Best regards
Ola Lie
I found a workaround.
In node-RED when I deploy a fcm-push node, I get a red circle indicating an error with no description.
However, it works when I send a push notifications using the fcm-push package.
So, I made a function node in Node-Red doing the same thing, adding the fcm-push module under the setup tab.
Conclusion: I am not using Node-red-contrib-fcm-push-node
