"node-red-contrib-fritz" push data to "node-red-contrib-influxdb"
Hi guys,
I want to pull data from my fritzbox with node-red-contrib-fritz and send it to influxdb with node-red-contrib-influxdb.
My output from fritzbox looks like this
msg.payload : Object
object
NewTotalBytesSent: "693542844"
3
and it should be formated to this specific dashboard.json:
https://grafana.com/api/dashboards/713/revisions/5/download
So that the dashboard works right from the scratch in grafana.
Can you guys help me with a function or a node?
Thx!
greetz duffy6
dashboard.json (shortend due max size limit for topics in this forum):
  "__inputs": [
      "name": "DS_INFLUX-COLLECTD",
      "label": "Influx-collectd",
      "description": "",
      "type": "datasource",
      "pluginId": "influxdb",
      "pluginName": "InfluxDB"
  "__requires": [
      "type": "panel",
      "id": "gauge",
      "name": "Gauge",
      "version": ""
      "type": "grafana",
      "id": "grafana",
      "name": "Grafana",
      "version": "6.5.3"
      "type": "panel",
      "id": "graph",
      "name": "Graph",
      "version": ""
      "id": "influxdb",
      "name": "InfluxDB",
      "version": "1.0.0"
      "type": "panel",
      "id": "singlestat",
      "name": "Singlestat",
      "version": ""
      "type": "panel",
      "id": "table",
      "name": "Table",
      "version": ""
  "annotations": {
    "list": [
        "builtIn": 1,
        "datasource": "-- Grafana --",
        "enable": true,
        "hide": true,
        "iconColor": "rgba(0, 211, 255, 1)",
        "name": "Annotations & Alerts",
        "type": "dashboard"
  "description": "Monitor FRITZ!Box routers.",
  "editable": true,
  "gnetId": 713,
  "graphTooltip": 2,
  "id": null,
  "links": [],
  "panels": [
      "cacheTimeout": null,
      "colorBackground": true,
      "colorValue": false,
      "colors": [
        "rgba(245, 54, 54, 0.9)",
        "rgba(237, 129, 40, 0.89)",
        "#1f78c1"
      "datasource": "${DS_INFLUX-COLLECTD}",
      "format": "none",
      "gauge": {
        "maxValue": 100,
        "minValue": 0,
        "show": false,
        "thresholdLabels": false,
        "thresholdMarkers": true
      "id": 10,
      "interval": null,
      "links": [],
      "mappingType": 1,
      "mappingTypes": [
          "name": "value to text",
          "value": 1
          "name": "range to text",
          "value": 2
      "maxDataPoints": 100,
      "nullPointMode": "connected",
      "nullText": null,
      "options": {},
      "postfix": "",
      "postfixFontSize": "50%",
      "prefix": "",
      "prefixFontSize": "50%",
      "rangeMaps": [
          "from": "null",
          "text": "N/A",
          "to": "null"
      "sparkline": {
        "fillColor": "rgba(31, 118, 189, 0.18)",
        "full": false,
        "lineColor": "rgb(31, 120, 193)",
        "show": false
      "tableColumn": "",
      "targets": [
          "dsType": "influxdb",
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
          "measurement": "fritzbox_value",
          "orderByTime": "ASC",
          "policy": "default",
          "refId": "A",
          "resultFormat": "time_series",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "last"
          "tags": [
              "key": "type_instance",
              "operator": "=",
              "value": "constatus"
          "target": ""
      "thresholds": "1,1",
      "title": "Connection Status",
      "type": "singlestat",
      "valueFontSize": "80%",
      "valueMaps": [
          "op": "=",
          "text": "N/A",
          "value": "null"
          "op": "=",
          "text": "Disconnected",
          "value": "0"
          "op": "=",
          "text": "Connected",
          "value": "1"
      "valueName": "current"
      "colors": [
        "#1f78c1"
      "format": "none",
      "gauge": {
        "maxValue": 100,
        "minValue": 0,
        "show": false,
      "gridPos": {
        "h": 3,
        "w": 6,
        "x": 6,
        "y": 0
      "id": 9,
      "interval": null,
      "links": [],
      "mappingType": 1,
      "mappingTypes": [
          "value": 1
          "value": 2
      "nullText": null,
      "options": {},
      "postfix": "",
      "prefix": "",
      "rangeMaps": [
          "from": "null",
          "text": "N/A",
          "to": "null"
      "sparkline": {
        "full": false,
        "show": false
      "tableColumn": "",
      "targets": [
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
          "refId": "A",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "last"
          "tags": [
              "operator": "=",
              "value": "dslstatus"
          "target": ""
      "title": "DSL Link Status",
      "valueMaps": [
          "op": "=",
          "text": "N/A",
          "value": "null"
          "op": "=",
          "value": "0"
          "op": "=",
          "value": "1"
      "gridPos": {
        "h": 6,
        "w": 6,
        "x": 12,
        "y": 0
      "id": 11,
      "links": [],
      "options": {
        "fieldOptions": {
          "calcs": [
            "lastNotNull"
          "defaults": {
            "decimals": 1,
            "mappings": [
                "id": 0,
                "op": "=",
                "text": "N/A",
                "type": 1,
                "value": "null"
            "max": 116000000,
            "min": 0,
            "nullValueMode": "connected",
            "thresholds": [
                "color": "green",
                "value": null
                "color": "rgba(237, 129, 40, 0.89)",
                "value": 50000000
                "color": "red",
                "value": 100000000
            "unit": "bps"
          "override": {},
          "values": false
        "orientation": "horizontal",
        "showThresholdLabels": false,
        "showThresholdMarkers": true
      "pluginVersion": "6.5.3",
      "targets": [
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
          "refId": "A",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "last"
          "tags": [
              "operator": "=",
              "value": "receiverate"
          "target": ""
      "title": "Current Download",
      "type": "gauge"
      "gridPos": {
        "h": 6,
        "w": 6,
        "x": 18,
        "y": 0
      "id": 12,
      "links": [],
      "options": {
        "fieldOptions": {
          "calcs": [
            "lastNotNull"
          "defaults": {
            "decimals": 1,
            "mappings": [
                "id": 0,
                "op": "=",
                "text": "N/A",
                "type": 1,
                "value": "null"
            "max": 40000000,
            "min": 0,
            "thresholds": [
                "color": "blue",
                "value": null
                "color": "green",
                "value": 5000000
                "value": 10000000
                "color": "#e24d42",
                "value": 30000000
            "unit": "bps"
          "override": {},
          "values": false
      "targets": [
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
          "refId": "A",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "last"
          "tags": [
              "operator": "=",
              "value": "sendrate"
          "target": ""
      "title": "Current Upload",
      "type": "gauge"
      "colorBackground": false,
      "colors": [
        "rgba(50, 172, 45, 0.97)"
      "decimals": 1,
      "format": "dtdurations",
      "gauge": {
        "maxValue": 100,
        "minValue": 0,
        "show": false,
      "gridPos": {
        "h": 3,
        "w": 6,
        "x": 0,
        "y": 3
      "id": 13,
      "interval": null,
      "links": [],
      "mappingType": 1,
      "mappingTypes": [
          "value": 1
          "value": 2
      "nullText": null,
      "options": {},
      "postfix": "",
      "prefix": "",
      "rangeMaps": [
          "from": "null",
          "text": "N/A",
          "to": "null"
      "sparkline": {
        "full": false,
        "show": false
      "tableColumn": "",
      "targets": [
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
          "refId": "A",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "last"
          "tags": [
              "operator": "=",
              "value": "uptime"
          "target": ""
      "title": "Uptime",
      "valueMaps": [
          "op": "=",
          "text": "N/A",
          "value": "null"
      "colors": [
      "decimals": 1,
      "gauge": {
        "maxValue": 100,
        "minValue": 0,
        "show": false,
      "gridPos": {
        "h": 3,
        "w": 6,
        "x": 6,
        "y": 3
      "id": 21,
      "interval": null,
      "links": [],
      "mappingType": 1,
      "mappingTypes": [
          "value": 1
          "value": 2
      "nullText": null,
      "options": {},
      "postfix": "",
      "prefix": "",
      "rangeMaps": [
          "from": "null",
          "text": "N/A",
          "to": "null"
      "sparkline": {
        "full": false,
        "show": false
      "tableColumn": "",
      "targets": [
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
          "refId": "A",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "last"
          "tags": [
              "key": "type",
              "operator": "=",
              "value": "uptime"
          "target": ""
      "title": "Uptime",
      "valueMaps": [
          "op": "=",
          "text": "N/A",
          "value": "null"
          "op": "=",
          "value": "0"
          "op": "=",
          "value": "1"
      "colors": [
      "decimals": 1,
      "format": "decbytes",
      "gauge": {
        "maxValue": 100,
        "minValue": 0,
        "show": false,
      "gridPos": {
        "h": 4,
        "w": 6,
        "x": 0,
        "y": 6
      "id": 3,
      "interval": null,
      "links": [],
      "mappingType": 1,
      "mappingTypes": [
          "value": 1
          "value": 2
      "nullText": null,
      "options": {},
      "postfix": "",
      "prefix": "",
      "rangeMaps": [
          "from": "null",
          "text": "N/A",
          "to": "null"
      "sparkline": {
        "full": false,
        "show": true
      "tableColumn": "",
      "targets": [
          "groupBy": [],
          "query": "SELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"fritzbox_value\" WHERE (\"type_instance\" = 'totalbytesreceived') AND $timeFilter GROUP BY time($__interval)",
          "rawQuery": false,
          "refId": "A",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [
                  "10s"
                "type": "non_negative_derivative"
          "tags": [
              "operator": "=",
              "value": "totalbytesreceived"
          "target": ""
      "thresholds": "",
      "title": "Total Download",
      "valueFontSize": "100%",
      "valueMaps": [
          "op": "=",
          "text": "N/A",
          "value": "null"
      "valueName": "total"
      "colorPrefix": true,
      "colors": [
      "decimals": 1,
      "gauge": {
        "maxValue": 100,
        "minValue": 0,
        "show": false,
      "gridPos": {
        "h": 4,
        "w": 6,
        "x": 6,
        "y": 6
      "id": 8,
      "interval": null,
      "links": [],
      "mappingType": 1,
      "mappingTypes": [
          "value": 1
          "value": 2
      "nullText": null,
      "options": {},
      "postfix": "",
      "prefix": "",
      "rangeMaps": [
          "from": "null",
          "text": "N/A",
          "to": "null"
      "sparkline": {
        "fillColor": "rgba(137, 15, 2, 0.18)",
        "full": false,
        "lineColor": "#e24d42",
        "show": true
      "tableColumn": "",
      "targets": [
          "groupBy": [],
          "query": "SELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"fritzbox_value\" WHERE (\"type_instance\" = 'totalbytessent') AND $timeFilter GROUP BY time($__interval)",
          "rawQuery": false,
          "refId": "A",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "non_negative_difference"
          "tags": [
              "operator": "=",
              "value": "totalbytessent"
          "target": ""
      "thresholds": "",
      "title": "Total Upload",
      "valueMaps": [
          "op": "=",
          "text": "N/A",
          "value": "null"
      "colors": [
      "decimals": 1,
      "gauge": {
        "maxValue": 100,
        "minValue": 0,
        "show": false,
      "gridPos": {
        "h": 4,
        "w": 6,
        "x": 12,
        "y": 6
      "hideTimeOverride": false,
      "id": 22,
      "interval": "",
      "links": [],
      "mappingType": 1,
      "mappingTypes": [
          "value": 1
          "value": 2
      "nullText": null,
      "options": {},
      "postfix": "",
      "prefix": "",
      "rangeMaps": [
          "from": "null",
          "text": "N/A",
          "to": "null"
      "sparkline": {
        "full": false,
        "show": true
      "tableColumn": "",
      "targets": [
          "groupBy": [],
          "query": "SELECT cumulative_sum(max(\"value\")) FROM \"fritzbox_value\" WHERE (\"type_instance\" = 'totalbytesreceived') AND $timeFilter GROUP BY time($__interval) tz('Europe/Berlin')",
          "rawQuery": false,
          "refId": "A",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
          "tags": [
              "operator": "=",
          "target": ""
      "thresholds": "",
      "timeFrom": "1d",
      "timeShift": null,
      "title": "Last 24h Download",
      "valueMaps": [
          "op": "=",
          "text": "N/A",
          "value": "null"
      "colors": [
      "decimals": 1,
      "gauge": {
        "maxValue": 100,
        "minValue": 0,
        "show": false,
(XXXXXXX shortend due to max size in topic)
What did you try yourself ? Did you read the documentation for both node-red and the influxdb nodes ?
Yes, of course!
But sad but true: I am a rookie.
So I am very happy for any hint.
Rather than looking at the JSON for the dashboard you have to look and see what query is run for the parameter you are interested in.
However, I don't understand how you have a dashboard that you need to provide the data for, when you haven't got a database containing the data yet. It all seems the wrong way round.
Because I do not want to build the dashboard.
It‘s a lot of work so I manipulate the data steucture in nodered before to make it fit
First step would be to transform data format to integer because right now it is a string in influx.
Any suggestions for transforming string to integer.
Is „numbers“ the right way?
If you have already written a field value as a string then (as far as I know) there is no way to change it other than dropping the measurement and starting again, making sure that the first value you write is a number.
What query is the dashboard running to get the value or values you want?
I managed to write in influxdb as value with JSONATA code in a change-node:
$number(msg.payload.NewTotalBytesSent)
and as node:
[{"id":"61b9b174.bbcd98","type":"inject","z":"a4b62e3a.73a728","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":456.8833312988281,"y":327.8833312988281,"wires":[["9fe07c7f.fe28f"]]},{"id":"9fe07c7f.fe28f","type":"fritzbox-in","z":"a4b62e3a.73a728","device":"c550fc2a.5bed58","name":"","service":"urn:dslforum-org:service:WANCommonInterfaceConfig:1","action":"GetTotalBytesSent","arguments":"{}","x":668.4999694824219,"y":328.88336181640625,"wires":[["90f30ea9.e5e3d"]]},{"id":"7029e75.ed89698","type":"influxdb out","z":"a4b62e3a.73a728","influxdb":"1c0b876b.560501","name":"fritzbox_value","measurement":"fritzbox_value","precision":"","retentionPolicy":"","database":"db1","precisionV18FluxV20":"ms","retentionPolicyV18Flux":"","org":"organisation","bucket":"bucket","x":1238.38330078125,"y":323.1166687011719,"wires":[]},{"id":"2653d3c4.b5d84c","type":"debug","z":"a4b62e3a.73a728","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1218.88330078125,"y":212.11663818359375,"wires":[]},{"id":"90f30ea9.e5e3d","type":"change","z":"a4b62e3a.73a728","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number(msg.payload.NewTotalBytesSent)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":880.88330078125,"y":326.8833312988281,"wires":[["2653d3c4.b5d84c","7029e75.ed89698"]]},{"id":"c550fc2a.5bed58","type":"fritzbox-config","name":"fritzbox_home","host":"192.168.133.1","port":"49443","ssl":true,"user":"doesnotexist"},{"id":"1c0b876b.560501","type":"influxdb","hostname":"192.168.133.109","port":"8086","protocol":"http","database":"db1","name":"influxdb","usetls":false,"tls":"","influxdbVersion":"1.8-flux","url":"http://192.168.133.102:8086","rejectUnauthorized":false}]
this gives me:
222
@Colin: To answer your question: the query in the dashboard is:
"query": "SELECT mean(\"value\") FROM \"fritzbox_value\" WHERE (\"type_instance\" = 'totalbytesreceived') AND $timeFilter GROUP BY time($interval) fill(null)",
So how do I have to modify my change-node to use this query?
greetz
duffy6
So the field is value, the measurement is fritzbox_value and there is a tag called type_instance with the value totalbytesreceived. But presumably, since you are doing this, you knew that already.
Have a look at the help for the influx node and you can work out what you need in the payload.
