Node-red-contrib-ifttt : IFTTT Read error
I want to control my fujitsu heat pump. No node seems to exist to control my device. So I want to go through IFTTT. I installed node-red-contrib-ifttt. Communication is not very stable. I often get the error messages. Since this morning these messages are displayed non-stop.:
IFTTT Read error
SyntaxError: Unexpected token u in JSON at position 0
refresh token error: "
  1. failed attempts. Waiting 100 ms before next attempt.
  2. failed attempts. Waiting 900 ms before next attempt.
  3. failed attempts. Waiting 8100 ms before next attempt.
  4. failed attempts. Waiting 72900 ms before next attempt.
    too many refresh attempts, giving up
Here is a very simple example where I want to turn off my heat pump
[{"id":"2907ebb6.e37fe4","type":"ifttt out","z":"8b8e905c.37879","eventName":"ThermopompeOff","key":"123","x":490,"y":260,"wires":[]},{"id":"123","type":"ifttt-key"}]
Update :
When I trigger the ifttt outside of nodered, my heat pump reacts well and I have no errors. I also did a new deployment of node red. I no longer get error messages all the time.
You could not use the ifttt node and send the http request direct using the http request node.
