Node-red-contrib-ikea-tradfri Help needed
I need help with turning on lamps, if i use inject node it always work with boolean.
but from plc that also use boolean, i got error.
i have tryed many combinations , nothing works !
it is Lampa_ToalettNere
best reg Donny
Check the input from the PLC with a debug node to ensure it is actually a valid boolean
That does not change anything, i have tried other things to trigger a function block.
it only works if i trigger with inject node, i can send a timestamp or whatever and it will work.
but in automatic flow it will not.
    msg.payload = {
        "onOff":  true
Print the whole message in debug node, not just the payload.
Thank you,
i found it, there was an hidden topic,
added delete msg.topic; to the function block.
and now it works :slight_smile:
