Hi, First of all, I have to say thank you for accepting me to this forum and sorry if my English is bad. I have a project with node-red and raspberry pi, I want to send an input signal to raspberry pi from a PLC and see the signal in a TCP server ( Hercules ). With inject node I can see the signal (1, 0) in Hercules at a specified time ( interval, interval between times, ...) but it doesn't work for me, What I need is to see the signal whenever it changes from 5 volts to 0 volts and vice versa. Please let me know if you have any suggestion? Thanks
Can you show us the values returned from the PLC?
Can you confirm the values you want to send over TCP (strings? booleans? bytes?)
Can you confirm I understand your requirements ...
- When value from PLC changes from EXACTLY
5to0- Send
0as a byte value to the TCP node - ONCE ONLY (until value changes)
- Send
0to5- Send
1as a byte value to the TCP node - ONCE ONLY (until value changes)
- Send
the value I see in TCP server is string. like input1:1,input2:1,input3:0,input4:1, ... but they are sent every 10 second according my injection nodes setting .
Yes, exactly my requirement is this.
