Send or intercept inject node only when required
I have the following question.
an Inject Node should trigger my AVR amplifier every few seconds to get the status. But when the amplifier is off, I get error messages all the time.
Can I set up the Inject Node so that the payload only goes through when a ping arrives?
Thank you very much for your support
Roland
somehow between Inject and Get Node as an example
The ping node will return: a number if it gets a response, or else false.
Use a switch node to only pass the message if msg.payload is a number, then a change node to setup whatever you need for your get zone status node.
Since the ping node can fire at specified intervals, no need for an inject node.
Hello jbudd,
yes, that's what I thought too ...
I think it could work like this
