I ran into a issue with the connection of my Knx installation and my Nodered.
I´m running Nodered local in a Milesight Gateway.
My problem is when I´m using KNX easy node my connection, disconnects. I have to disconnect the network from the Ip interface to get it running again but it fails after a while again.
Any thoughts?
Regards
Hi, tip: use this node ![]()
