Node-red-contrib-maps : maps - HOW TO
Guys , does anyone know how to use this node ? node-red-contrib-maps : maps
I am receiving data from an API of a map and its elements , I want to plot it in node red . Could you suggest a way to go about it ?
I will be drawing data from here : V2 - Flemish Banks Monitoring Network API
To gain access you will need to create an account here :https://meetnetvlaamsebanken.be/
I see that node was last updated 3 years ago, while this one was last updated 3 weeks ago. The maintainer is a chap of some repute in the Node-red community too.
Can you achieve what you are after with the worldmap node? There are several examples built-in to the node and I've seen a few in this forum.
Thank you sir , I will go through it. This is very helpful.
