Node-red-contrib-melsec Configuration
Hello everyone,
I am trying to connect a Mitsubishi FX3G-60M PLC to my Raspberry Pi using Node-RED. My goal is just to read some data to display on my dashboard.
I'm using the node-red-contrib-melsec-fx nodes and am having trouble configuring the serial port (e.g., /dev/ttyACM0).
I thought the serial port settings would be inside the melsec-fx-in node, but I can't find them. The node only asks me to select a "Melsec FX endpoint," as you can see in this screenshot:
I guess the serial port configuration must be inside that "Melsec FX endpoint" node, but I don't know how to access or edit it.
Could someone please point me in the right direction?
Thank you!
Hi, welcome to the forum
Have you tried clicking the pencil button to the right of "Melsec FX endpoint"?
As you are a new user, I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
Hi @Steve-Mcl,
I clicked the pencil icon as you suggested:
That opened the endpoint configuration node, which shows these options:
I am trying to retrieve data from the Mitsubishi PLC using its programming port, not the Ethernet port, which is why I was looking for the serial settings.
My confusion came from the fact that I have some experience retrieving data from Siemens PLCs using Node-RED, and those nodes handle the connection settings differently."
Yeah, I have not used that node and seen you were a new user and (wrongly) assumed you were also new to Node-RED (they are still worth a watch if you've not seem them - a few good tips and tricks in there)
So, i am surprised there is no serial settings on that config node also!?
However, a clue lies in the nodes source code: node-red-contrib-melsec/red/melsec.js at abdf6d71013873bf44908f79cf3ec175f2e78065 · st-one-io/node-red-contrib-melsec · GitHub
if (!melsecAdapter) return that.error('Missing "@protocols/node-melsec" dependency, avaliable only on the ST-One hardware. Please contact us at "st-one.io" for pricing and more information.')
I.e. it looks like this requires ST-One hardware (and I guess thats where the setup is done)
If you are familiar with JavaScript, you could DIY this in a function node using node-fxplc node module. The readme has example code on how to connect serial and read/write addresses
See article Use any npm module in Node-RED for getting started with npm node modules.
Thank you very much for your help :folded_hands: much appreciated
In the interest of sharing, if you have developed a working example, it would be good to post that on the forum for future readers. Perhaps in this thread or linked to a post in Share Your Projects would be great.
Ta. Steve.
