Excuse me
Mitsubishi PLC FX5U Ethernet to HUB wants to control X, Y, D through the built-in Node-red node of Raspberry Pi. Is there any tutorial on this?
There is a contrib node for MC Protocol node-red-contrib-mcprotocol (node) - Node-RED
install that & give it a go.
If you are new to node-red, I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
Here is a thread on the repository where a user got it to work with FX PLC
Sorry, do you have a physical operation video, because it is a novice relationship
i need help for that Topic too. Please do you have aoperational video??
No, sorry.
What is your issue? Have you setup UDP ports on the PLC? What error are you seeing? What settings have you entered on the node config?
