i have programmed Mitsubishi plc FX5U-32M using GX Works and i want to send PLC data to Schneider Magelis IOT gateway so please help me (How to connect Mitsubishi PLC FX5U-32M to Node red using node's available in Node red and Without using OPC server / Kepware)
Hi, did you find a solution at the end?
Hi sandeepanj , I have just view a manual of Mitsubishi. I think that support a modbus tcp protocol.
Hi, I have an FX3u and I'm interested in this topic. We could join our efforts
Hi @Lupin_III, @sandeepanj if you are interested in testing, I have just published this node to github - node-red-contrib-mcprotocol
If you are willing to test it out I can assist you.
Essentially, you can install it like so...
cd ~/.node-red
npm install Steve-Mcl/node-red-contrib-mcprotocol
After install, re-start node-red. You should have 2 mcprotocol nodes read + write
The built in help in the side-bar info panel should get you going.
Hi Steve, it would have been perfect but at the moment the PLC is connected via RS232 ... damn!
