Hi There,
The problem which i faced for Fx3U has got solved. and i would tell the Plc Guy to Change TCP to UDP as you Suggested me.
But i have another Issue with Fx5U which one plc is master and other are slave
the issue is that it is not communicating with mc protocol as i faced issue with Fx3U but i tried to play with the Bellow Details
These settings are not set (default)
-Network No
-PC No
-Dest Module
-Dest Module Stn No
But the issue is same, and it is working on KepServer Still i got a Old Data from him about that PLC which i am sharing you the Screenshot.
I will re-ask my question in short.
My PLC is FX5u - Running on TCP-IP 191.168.2.10 (it is master plc and it has two slave plcs of same model) ignoring slaves and I want to communicate with master PLC.
Communication from Melsoft GX works3 happens smoothly.
If you have a spare FX5 PLC and wish to donate it to me, i will endevour to upgrade and improve the MC Protocol nodes. without a PLC to play with, i am working blind.
What about Multiple Address to handle in 1 node is it possible to use and i need to show it as UI separated For FX3U as i posted you the Screenshot where i add every single node for every address.
The IP set in port 1 does not match so you cannot use that one
2 (MELSEC) wont work
3 (SLMP) is possible - but you have already tried that
4 is a socket (AKA RAW ethernet) (not MC protocol) - that wont work
Question. Is No 4 (the raw socket) used for anything? If not, set it to SLMP UDP & give that a go.
Question. If you remove the IP (or set it to 255.255.255.255) on connection No 1, you will be able to connect to that (the IP currently set in that row will prevent .100 connecting)
PS I am a little concerned that 3 and 4 have the same PORT number and are both TCP. That may be a factor!
Example - look at these - all similar screenshots have different port numbers!
EDIT
Any changes you make in the PLC Open settings WILL need the PLC to be power cycled (because Mitsi still think its 1980!)
and other on 192.168.2.11,12,13 has a HMI
Now the Thing is that the Plc Guy says he cannot change anything in program setting as the PLC came Configured by Chinese Man and they are not giving the access to this PLC
So is there any other way to get.
is there any way to connect me on my laptop or can you provide your contact for better understanding
Not sure what the question means. but if you mean "can your personal laptop connect" then probably not - due to the afore mentioned ill configured settings in the PLC that should be changed
