I changed to UDP From TCP for Mitsubishi PLC Fx3u but did not work in NodeRED
as per the previous Topic @Steve-Mcl told me to Change it from TCP to UDP and i did but its not working now
What do you see? how did you setup PLC? are node-red server and PLC on same network?
I just see timeout error in nodeRED and both are in same network both are pinging
@Steve-Mcl
"POLLING": "ENABLED",
"payload": null,
"_msgid": "e722627803c06cc2",
"_event": "node:30608999c586eb0a",
"topic": "D40,9",
"_linkSource": [
"id": "0530ddbb9d9908a47f8fc8a21d81",
"node": "93091528e94e02c3"
"mcReadDetails": {
"request": {
"outputFormat": "Array",
"address": "D40,9",
"timeStamp": 1761575618296
"response": {
"isGood": false,
"quality": [
"Unknown",
"Unknown",
"Unknown",
"Unknown",
"Unknown",
"Unknown",
"Unknown",
"Unknown",
"Unknown"
"TAG": "D40,9",
"addr": "D40,9",
"timeTaken": 4501,
"timeStamp": 1761575622797,
"value": [
0,
0,
0,
0,
0,
0,
0,
0,
0
"valueType": "INT",
"deviceCode": "D",
"deviceCodeNotation": "Decimal",
"deviceCodeType": "WORD",
"digitSpec": "",
"dataType": "INT",
"dataTypeByteLength": 2,
"deviceNo": 40,
"problem": true
"error": true
"error": {
"message": "Error",
"source": {
"id": "05cd47ebd2cf785f",
"type": "MC Read",
"count": 1
"stack": "Error\n at handleError (/home/omsoftware/.node-red/node_modules/node-red-contrib-mcprotocol/nodes/read.js:74:17)\n at PLCItem.myReply [as cb] (/home/omsoftware/.node-red/node_modules/node-red-contrib-mcprotocol/nodes/read.js:207:11)\n at MCProtocol.readResponse (/home/omsoftware/.node-red/node_modules/node-red-contrib-mcprotocol/mcprotocol/mcprotocol.js:1797:14)\n at MCProtocol.packetTimeout (/home/omsoftware/.node-red/node_modules/node-red-contrib-mcprotocol/mcprotocol/mcprotocol.js:465:8)\n at Timeout.<anonymous> (/home/omsoftware/.node-red/node_modules/node-red-contrib-mcprotocol/mcprotocol/mcprotocol.js:1383:24)\n at listOnTimeout (node:internal/timers:583:11)\n at process.processTimers (node:internal/timers:519:7)"
@Steve-Mcl ,
Can you Please Tell me what i am missing. or am i wrong
Not without information
Can you show me the settings you have made in the config node?
@Steve-Mcl ,
here is the config
@Steve-Mcl ,
Hi there i dont know whether it will work on that or not are your sure about the solution you gave because before i have using TCP with the above config it was working
No. That's why I called it Test1
If it does not work I will probably provide a Test2
FYI: I have not used that particular PLC model, I am not familiar with your network hardware, routing, settings, etc, etc, etc. In short, I dont have enough details (nor do I have enough time to ask for and wait for answers) so I am taking a logic step-wise approach and asking you to "try stuff".
Are they on the same network segment? IE connected to the same router, not through another router or wifi mesh or similar.
@Colin ,
Yes there is a special router for the plc and device we separated the router for them and they are in same network .
What details are required more please specify me so i can try to provide you with that.
Please try the suggestion first.
If that doesn't work, we will explore other ideas.
I don't fully understand that sentence, but if there are two routers between you and the plc then udp may not get through, even if logically you are on the same network.
@Colin ,
In simple word there is only 1 router for plc and device
It's not that then.
@Steve-Mcl and @Colin,
I have updated to ur port and tried but still not worked timeout and also i tried port 5000
which screenshot is below
i have got updated in nodered but still i cant use it
Bear in mind that i know zero about industrial PLCs.
Steve suggested using port 5500 both in the PLC config and in Node-red. Did you try this?
To my untutored eyes it looks like the PLC is sending data to port 5001 while Node-red is listening on port 5000?
avoid 5000 and 5001
5000 is often the UDP default for protocols that support Auto Open UDP Port features, or when configured for certain SCADA systems/HMIs.
|5001 is often the default TCP for communication like SCADA, HMIs, or other clients connecting to the PLC's dedicated Ethernet module (e.g., QJ71E71).
