Node-red-contrib-mqtt-sparkplug-plus
hello, im making an application with nodered to replace some softwares used like Edge nodes sending information trhough MQTT Spark plug B , I have accomplished read tags from plc , robots, some brokers and this really works. but other functionality that i need to replace, is the bidireccionality of the published data, is possible with "node-red-contrib-mqtt-sparkplug-plus" ?
Have you read the Flows Page which gives information about the node, or the help tab in the Right Hand Side Editor window (with the node installed)?
These may help you get the answer to your question.
