Can anybody help me about debugging the following error.
I tried with different data types, but I couldn't find out where the problem is after many hours.
This was a working solution until I updated the mssql-plus module.
Node-Red Log:
21 Feb 13:33:39 - [info] Starting flows
21 Feb 13:33:39 - [info] Started flows
21 Feb 13:33:39 - [info] [mqtt-broker:35f072cb3207907c] Connected to broker: mqtt://...
21 Feb 13:33:39 - [info] [mqtt-broker:da531418c5b0fb46] Connected to broker: mqtt://...
21 Feb 13:33:41 - [info] [MSSQL-CN:DECKLACK] Connected to server : ...\SCHMID_CELL, database : DECKLACK, port : 1433, user : Grafana_Decklack
21 Feb 13:34:01 - [info] [MSSQL-CN:Node-Red Teszt] Connected to server : ...\SCHMID_CELL, database : NODE-RED_TESZT, port : 1433, user : Grafana_test
21 Feb 13:34:01 - [info] [MSSQL-CN:Node-Red Teszt] Error connecting to server : ...\SCHMID_CELL, database : NODE-RED_TESZT, port : 1433, user : Grafana_test
RequestError: Invalid string.
at BulkLoad.done [as callback] (C:\Users\OkumaIoT.JOST10\.node-red\node_modules\mssql\lib\tedious\request.js:307:19)
at Parser.onEndOfMessage (C:\Users\OkumaIoT.JOST10\.node-red\node_modules\tedious\lib\connection.js:2823:22)
at Object.onceWrapper (node:events:509:28)
at Parser.emit (node:events:390:28)
at Parser.emit (node:domain:475:12)
at Readable.<anonymous> (C:\Users\OkumaIoT.JOST10\.node-red\node_modules\tedious\lib\token\token-stream-parser.js:32:12)
at Readable.emit (node:events:390:28)
at Readable.emit (node:domain:475:12)
at endReadableNT (node:internal/streams/readable:1343:12)
at processTicksAndRejections (node:internal/process/task_queues:83:21) {
code: 'EREQUEST',
originalError: TypeError: Invalid string.
at Object.validate (C:\Users\OkumaIoT.JOST10\.node-red\node_modules\tedious\lib\data-types\varchar.js:118:13)
at RowTransform._transform (C:\Users\OkumaIoT.JOST10\.node-red\node_modules\tedious\lib\bulk-load.js:116:26)
at RowTransform.Transform._write (node:internal/streams/transform:184:23)
at writeOrBuffer (node:internal/streams/writable:389:12)
at _write (node:internal/streams/writable:330:10)
at RowTransform.Writable.write (node:internal/streams/writable:334:10)
at Readable.ondata (node:internal/streams/readable:754:22)
at Readable.read (node:internal/streams/readable:527:10),
number: undefined,
lineNumber: undefined,
state: undefined,
class: undefined,
serverName: undefined,
procName: undefined,
precedingErrors: []
21 Feb 13:34:01 - [error] [MSSQL:Teszt] Invalid string.
mssql-table:
USE [NODE-RED_TESZT]
GO
/****** Object: Table [dbo].[Okuma_SF_teszt] Script Date: 2024. 02. 21. 13:38:10 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE TABLE [dbo].[Okuma_SF_teszt](
[MachineNo] [int] NULL,
[MacType] [varchar](50) NULL,
[MachineName] [varchar](50) NULL,
[Date] [datetime] NULL,
[PowerOn] [bit] NULL,
[AlarmState] [bit] NULL,
[LimitState] [bit] NULL,
[ProgramStopState] [bit] NULL,
[FeedHoldState] [bit] NULL,
[STMState] [bit] NULL,
[RunState] [bit] NULL,
[CuttingState] [bit] NULL,
[SetUp] [bit] NULL,
[NoOperator] [bit] NULL,
[Wait] [bit] NULL,
[Maintenance] [bit] NULL,
[Other] [bit] NULL,
[ManualMode] [bit] NULL,
[MDIMode] [bit] NULL,
[AutoMode] [bit] NULL,
[MacManMode] [bit] NULL,
[ToolSetMode] [bit] NULL,
[OriginSetMode] [bit] NULL,
[ParameterSetMode] [bit] NULL,
[ProgramOpeMode] [bit] NULL,
[ProgramFileName] [varchar](50) NULL,
[AlarmLevel] [int] NULL,
[AlarmNo] [int] NULL,
[AlarmCode] [varchar](50) NULL,
[AlarmString] [varchar](50) NULL,
[AlarmMessage] [varchar](200) NULL,
[AlarmObject] [varchar](50) NULL,
[PowerOnTime] [int] NULL,
[AlarmStateTime] [int] NULL,
[AlarmRunStateTime] [int] NULL,
[LimitStateTime] [int] NULL,
[ProgramStopStateTime] [int] NULL,
[FeedHoldStateTime] [int] NULL,
[STMStateTime] [int] NULL,
[RunStateTime] [int] NULL,
[CuttingTime] [int] NULL,
[SpindleCMDTime] [int] NULL,
[TotalActivePower] [int] NULL,
[SetUpTime] [int] NULL,
[NoOperatorTime] [int] NULL,
[WaitTime] [int] NULL,
[MaintenanceTime] [int] NULL,
[OtherTime] [int] NULL,
[ManualModeTime] [int] NULL,
[MDIModeTime] [int] NULL,
[AutoModeTime] [int] NULL,
[MacManModeTime] [int] NULL,
[ToolSetModeTime] [int] NULL,
[OriginSetModeTime] [int] NULL,
[ParameterSetModeTime] [int] NULL,
[ProgramOpeModeTime] [int] NULL,
[FeedOverride] [int] NULL,
[SpindleOverride] [int] NULL
) ON [PRIMARY]
GO
flow:
msg object after function execution:
{"payload":[{"MachineNo":1,"MacType":0,"MachineName":"LU45II","Date":"2024-02-22T07:21:00.000Z","PowerOn":0,"AlarmState":0,"LimitState":0,"ProgramStopState":0,"FeedHoldState":0,"STMState":0,"RunState":0,"CuttingState":0,"SetUp":0,"NoOperator":0,"Wait":0,"Maintenance":0,"Other":0,"ManualMode":0,"MDIMode":0,"AutoMode":0,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":0,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"R-41654-FO.MIN","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":0,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":0,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":0,"RunStateTime":0,"CuttingTime":0,"SpindleCMDTime":0,"TotalActivePower":0,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":0,"MDIModeTime":0,"AutoModeTime":0,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":0,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":0,"SpindleOverride":0},{"MachineNo":2,"MacType":0,"MachineName":"LB4000EXII","Date":"2024-02-22T07:21:00.000Z","PowerOn":1,"AlarmState":0,"LimitState":1,"ProgramStopState":0,"FeedHoldState":0,"STMState":1,"RunState":1,"CuttingState":1,"SetUp":0,"NoOperator":0,"Wait":0,"Maintenance":1,"Other":0,"ManualMode":0,"MDIMode":0,"AutoMode":1,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":1,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"KMZ-41L006.MIN","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":60000,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":26000,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":6000,"RunStateTime":40000,"CuttingTime":40000,"SpindleCMDTime":34000,"TotalActivePower":100,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":20000,"OtherTime":0,"ManualModeTime":0,"MDIModeTime":0,"AutoModeTime":60000,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":60000,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":100,"SpindleOverride":100},{"MachineNo":3,"MacType":0,"MachineName":"You-Ji YV-1000A 2/1","Date":"2024-02-22T07:21:00.000Z","PowerOn":1,"AlarmState":0,"LimitState":0,"ProgramStopState":0,"FeedHoldState":0,"STMState":0,"RunState":0,"CuttingState":0,"SetUp":0,"NoOperator":0,"Wait":0,"Maintenance":0,"Other":0,"ManualMode":0,"MDIMode":0,"AutoMode":1,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":0,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":60000,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":0,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":0,"RunStateTime":0,"CuttingTime":0,"SpindleCMDTime":0,"TotalActivePower":0,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":0,"MDIModeTime":0,"AutoModeTime":60000,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":0,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":100,"SpindleOverride":100},{"MachineNo":4,"MacType":0,"MachineName":"You-Ji YV-1000A 2/2","Date":"2024-02-22T07:21:00.000Z","PowerOn":1,"AlarmState":0,"LimitState":0,"ProgramStopState":0,"FeedHoldState":0,"STMState":0,"RunState":0,"CuttingState":0,"SetUp":0,"NoOperator":0,"Wait":0,"Maintenance":0,"Other":0,"ManualMode":1,"MDIMode":0,"AutoMode":0,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":0,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":60000,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":0,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":0,"RunStateTime":0,"CuttingTime":0,"SpindleCMDTime":0,"TotalActivePower":0,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":60000,"MDIModeTime":0,"AutoModeTime":0,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":0,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":0,"SpindleOverride":100},{"MachineNo":5,"MacType":0,"MachineName":"You-Ji YV-1200A 1/2","Date":"2024-02-22T07:21:00.000Z","PowerOn":1,"AlarmState":0,"LimitState":0,"ProgramStopState":0,"FeedHoldState":0,"STMState":0,"RunState":0,"CuttingState":0,"SetUp":0,"NoOperator":0,"Wait":0,"Maintenance":0,"Other":0,"ManualMode":0,"MDIMode":0,"AutoMode":0,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":0,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":60000,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":0,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":0,"RunStateTime":0,"CuttingTime":0,"SpindleCMDTime":0,"TotalActivePower":0,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":0,"MDIModeTime":0,"AutoModeTime":0,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":0,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":0,"SpindleOverride":100},{"MachineNo":6,"MacType":0,"MachineName":"You-Ji YV-1200A 1/1","Date":"2024-02-22T07:21:00.000Z","PowerOn":1,"AlarmState":0,"LimitState":0,"ProgramStopState":0,"FeedHoldState":0,"STMState":0,"RunState":0,"CuttingState":0,"SetUp":0,"NoOperator":0,"Wait":0,"Maintenance":0,"Other":0,"ManualMode":0,"MDIMode":0,"AutoMode":1,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":0,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":60000,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":0,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":0,"RunStateTime":0,"CuttingTime":0,"SpindleCMDTime":0,"TotalActivePower":0,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":0,"MDIModeTime":0,"AutoModeTime":60000,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":0,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":100,"SpindleOverride":90},{"MachineNo":7,"MacType":0,"MachineName":"V920","Date":"2024-02-22T07:21:00.000Z","PowerOn":1,"AlarmState":0,"LimitState":1,"ProgramStopState":0,"FeedHoldState":0,"STMState":0,"RunState":0,"CuttingState":0,"SetUp":0,"NoOperator":0,"Wait":1,"Maintenance":0,"Other":0,"ManualMode":1,"MDIMode":0,"AutoMode":0,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":1,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"KDL-520OT-OP1.MIN","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":60000,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":60000,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":0,"RunStateTime":0,"CuttingTime":0,"SpindleCMDTime":3000,"TotalActivePower":100,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":60000,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":60000,"MDIModeTime":0,"AutoModeTime":0,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":60000,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":100,"SpindleOverride":100},{"MachineNo":8,"MacType":0,"MachineName":"Toyoda 630/1","Date":"2024-02-22T07:21:00.000Z","PowerOn":0,"AlarmState":0,"LimitState":0,"ProgramStopState":0,"FeedHoldState":0,"STMState":0,"RunState":0,"CuttingState":0,"SetUp":0,"NoOperator":0,"Wait":0,"Maintenance":0,"Other":0,"ManualMode":0,"MDIMode":0,"AutoMode":0,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":0,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":0,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":0,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":0,"RunStateTime":0,"CuttingTime":0,"SpindleCMDTime":0,"TotalActivePower":0,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":0,"MDIModeTime":0,"AutoModeTime":0,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":0,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":0,"SpindleOverride":0},{"MachineNo":9,"MacType":0,"MachineName":"Toyoda 630/2","Date":"2024-02-22T07:21:00.000Z","PowerOn":1,"AlarmState":0,"LimitState":0,"ProgramStopState":0,"FeedHoldState":0,"STMState":0,"RunState":1,"CuttingState":0,"SetUp":0,"NoOperator":0,"Wait":0,"Maintenance":0,"Other":0,"ManualMode":0,"MDIMode":0,"AutoMode":1,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":0,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":60000,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":0,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":0,"RunStateTime":60000,"CuttingTime":0,"SpindleCMDTime":60000,"TotalActivePower":0,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":0,"MDIModeTime":0,"AutoModeTime":60000,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":0,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":100,"SpindleOverride":100},{"MachineNo":11,"MacType":0,"MachineName":"Toyoda FH80S","Date":"2024-02-22T07:21:00.000Z","PowerOn":1,"AlarmState":0,"LimitState":0,"ProgramStopState":0,"FeedHoldState":0,"STMState":0,"RunState":0,"CuttingState":0,"SetUp":0,"NoOperator":0,"Wait":0,"Maintenance":0,"Other":0,"ManualMode":0,"MDIMode":0,"AutoMode":1,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":0,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":59000,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":0,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":0,"RunStateTime":0,"CuttingTime":0,"SpindleCMDTime":0,"TotalActivePower":0,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":0,"MDIModeTime":0,"AutoModeTime":58000,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":0,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":100,"SpindleOverride":0},{"MachineNo":12,"MacType":0,"MachineName":"MA600-PPS","Date":"2024-02-22T07:21:00.000Z","PowerOn":1,"AlarmState":0,"LimitState":1,"ProgramStopState":0,"FeedHoldState":0,"STMState":1,"RunState":1,"CuttingState":1,"SetUp":0,"NoOperator":0,"Wait":0,"Maintenance":0,"Other":0,"ManualMode":0,"MDIMode":0,"AutoMode":1,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":1,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"PPCKMZ-41L006.MIN","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":60000,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":3000,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":14000,"RunStateTime":60000,"CuttingTime":60000,"SpindleCMDTime":51000,"TotalActivePower":100,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":0,"MDIModeTime":0,"AutoModeTime":60000,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":60000,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":100,"SpindleOverride":100},{"MachineNo":13,"MacType":0,"MachineName":"MA600-CELL","Date":"2024-02-22T07:21:00.000Z","PowerOn":1,"AlarmState":0,"LimitState":1,"ProgramStopState":0,"FeedHoldState":0,"STMState":0,"RunState":0,"CuttingState":0,"SetUp":1,"NoOperator":0,"Wait":0,"Maintenance":0,"Other":0,"ManualMode":0,"MDIMode":0,"AutoMode":1,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":1,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"P1697.MIN","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":60000,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":60000,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":0,"RunStateTime":0,"CuttingTime":0,"SpindleCMDTime":60000,"TotalActivePower":100,"SetUpTime":60000,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":0,"MDIModeTime":0,"AutoModeTime":60000,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":60000,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":0,"SpindleOverride":100},{"MachineNo":14,"MacType":0,"MachineName":"MULTUS-B250-CELL","Date":"2024-02-22T07:21:00.000Z","PowerOn":0,"AlarmState":0,"LimitState":0,"ProgramStopState":0,"FeedHoldState":0,"STMState":0,"RunState":0,"CuttingState":0,"SetUp":0,"NoOperator":0,"Wait":0,"Maintenance":0,"Other":0,"ManualMode":0,"MDIMode":0,"AutoMode":0,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":0,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"P1697.MIN","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":0,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":0,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":0,"RunStateTime":0,"CuttingTime":0,"SpindleCMDTime":0,"TotalActivePower":0,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":0,"MDIModeTime":0,"AutoModeTime":0,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":0,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":0,"SpindleOverride":0},{"MachineNo":15,"MacType":0,"MachineName":"LB4000EXII_2","Date":"2024-02-22T07:21:00.000Z","PowerOn":1,"AlarmState":0,"LimitState":0,"ProgramStopState":0,"FeedHoldState":0,"STMState":1,"RunState":1,"CuttingState":1,"SetUp":0,"NoOperator":0,"Wait":0,"Maintenance":0,"Other":0,"ManualMode":0,"MDIMode":0,"AutoMode":1,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":1,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"FUR-KMZ-41654.MIN","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":60000,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":0,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":1000,"RunStateTime":60000,"CuttingTime":15000,"SpindleCMDTime":60000,"TotalActivePower":100,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":0,"MDIModeTime":0,"AutoModeTime":60000,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":60000,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":100,"SpindleOverride":100},{"MachineNo":16,"MacType":0,"MachineName":"V920_2","Date":"2024-02-22T07:21:00.000Z","PowerOn":1,"AlarmState":0,"LimitState":0,"ProgramStopState":0,"FeedHoldState":0,"STMState":0,"RunState":1,"CuttingState":1,"SetUp":0,"NoOperator":0,"Wait":0,"Maintenance":0,"Other":0,"ManualMode":0,"MDIMode":0,"AutoMode":1,"MacManMode":0,"ToolSetMode":0,"OriginSetMode":1,"ParameterSetMode":0,"ProgramOpeMode":0,"ProgramFileName":"BUSZ-KULSO-OP30.MIN","AlarmLevel":0,"AlarmNo":0,"AlarmCode":"","AlarmString":"","AlarmMessage":"","AlarmObject":0,"PowerOnTime":60000,"AlarmStateTime":0,"AlarmRunStateTime":0,"LimitStateTime":0,"ProgramStopStateTime":0,"FeedHoldStateTime":0,"STMStateTime":0,"RunStateTime":60000,"CuttingTime":33000,"SpindleCMDTime":60000,"TotalActivePower":0,"SetUpTime":0,"NoOperatorTime":0,"WaitTime":0,"MaintenanceTime":0,"OtherTime":0,"ManualModeTime":0,"MDIModeTime":0,"AutoModeTime":60000,"MacManModeTime":0,"ToolSetModeTime":0,"OriginSetModeTime":60000,"ParameterSetModeTime":0,"ProgramOpeModeTime":0,"FeedOverride":100,"SpindleOverride":100}],"topic":"c:\\\\okuma-share\\\\OutputFile\\\\","file":"20240222082400_OperationResult.csv","filename":"c:\\okuma-share\\OutputFile\\20240222082400_OperationResult.csv","event":"update","size":4068,"type":"file","_msgid":"e6e30e044d424e38","columns":"MachineNo,MacType,MachineName,Date,PowerOn,AlarmState,LimitState,ProgramStopState,FeedHoldState,STMState,RunState,CuttingState,SetUp,NoOperator,Wait,Maintenance,Other,ManualMode,MDIMode,AutoMode,MacManMode,ToolSetMode,OriginSetMode,ParameterSetMode,ProgramOpeMode,ProgramFileName,AlarmLevel,AlarmNo,AlarmCode,AlarmString,AlarmMessage,AlarmObject,PowerOnTime,AlarmStateTime,AlarmRunStateTime,LimitStateTime,ProgramStopStateTime,FeedHoldStateTime,STMStateTime,RunStateTime,CuttingTime,SpindleCMDTime,TotalActivePower,SetUpTime,NoOperatorTime,WaitTime,MaintenanceTime,OtherTime,ManualModeTime,MDIModeTime,AutoModeTime,MacManModeTime,ToolSetModeTime,OriginSetModeTime,ParameterSetModeTime,ProgramOpeModeTime,FeedOverride,SpindleOverride"}
error message object of mssql node:
{"code":"EREQUEST","message":"Invalid string.","details":"Invalid string.","name":"RequestError"}
csv file sample to read:
20240222083300_OperationResult.txt (4.0 KB)
flow:
flows (1).json (28.9 KB)
Thank you in advance.
