Hi.
I am trying to use node-red-contrib-noble-bluetooth module on Node-RED 2.1.4.
Installation of the package and required package @abandonware/noble went flawlessly. Unfortunately, the package is not present on the palette, and the dashboard displays an error ERR_DLOPEN_FAILED.
node version -> v17.3.0
Any ideas?
Based on this issue I'd guess node v17 is the problem.
Try downgrading to v14lts (I suspect v16 will also be an issue)
You were right. Downgrade nodejs to v14.18.2 helped.
Thx.
