Node-red-contrib-osc module issue: "missing node type"
Hi there,
i have a problem with the node-red-contrib-osc module.
Node-Red version 0.19.2.
node-red-contrib-osc version 1.1.0
Ubuntu 16.04 (lts)
I've installed the module by the palette manager.
Once installed, there was a first problem: in the installed modules list, the osc module had a red alert about "Object object"
See the pic: https://ibb.co/kf3Mcp
I have anyway the osc node in the nodes list.
But if i try to use it, i have this error:
"Flow stopped due to missing node types
osc"
See the other pic: https://ibb.co/dS5dOU
If i run "nodered -v", in the console have:
[info] Waiting for missing types to be registered:
[info] - osc
I've already tried to uninstall and reinstall several times, also removing the osc folder in the node_modules folder, and also installing via CLI.
I'm using the same module in other nodered instances on different system, but without problem at all.
Am i missing something?
Any tips?
cheers
M
what version of nodejs are you using?
Hi ukmoose,
you got it.
The nodejs version was 4.2.6 (quite strange, forgot to update)
After updating, the node module start working like a charm...
:slight_smile:
"solved" i'd say!
Thanks!
