Node-red-contrib-play-sound volume control
Hello!
is there a way to adjust node-red-contrib-play-sound volume levels from dashboard?
not according to them, from their github MattVador/node-red-contrib-play-sound: Node-RED node for play sound (github.com)
start (or empty): Start playing
stop: Stop all sound playing
pause: Pause all sound playing
resume: Resume all sound playing
The PlaySound node comprises the following options:
audioURI: File name or url to play - If empty, then the one in dialog is used
options: Options - If empty, then the one in dialog is used
Not directly, but there is an approach to changing the system volume on a Raspberry Pi, if that leads in a useful direction for you?
Take a look at this project I did awhile ago.
I used a dashboard silder to send the volume via an exec node to amixer on the Pi.
You could try that out.
