Music Player v1.0.0
I had some small Cambridge Soundwork speakers hanging around and wanted to do something with them, so I decided to use them with a RPi Zero W as a music box.
(I still have to figure out a better mounting method)
From the ReadMe:
This music player reads a folder (called 'songs') and will play the songs in alphabetical order.
Once all the songs have been played, it will restart the list.
You can Pause/Resume play, Skip to the next song, go to the previous song and stop playing any songs.
There is also a button to power off the Pi.
I designed this to allow it to be controled by an iPhone by turning on
the iPhone's Personal hotspot. To access it this way, you need to add the iPhone Hotspot name
and password to the wpa_supplicant.config file on the Pi.
This is running on Node-RED v0.20.5. with the following components and nodes:
a HiFiBerry MiniAmp hat (https://www.hifiberry.com/shop/boards/miniamp/) for an amplifier
node-red-contrib-fs-ops (v1.5.0) to get the sound file names
You will also have to install mplayer (sudo apt install mplayer) or change the play-sound node to use another player.
37%20AM
node-red-contrib-play-sound (v0.2.0) to control the playing of the songs and
an exec node running amixer to control the volume
and a second exec note to allow remote shutdown of the pi.
Here is the flow I built
[{"id":"c1c06219.7371","type":"tab","label":"Music Player - v1.0.0","disabled":false,"info":"v1.0.0 - first public release"},{"id":"9b2a50e4.6feb68","type":"fs-ops-dir","z":"c1c06219.7371","name":"Get filenames from /home/pi/songs","path":"/home/pi/songs","pathType":"str","filter":"*","filterType":"str","dir":"payload","dirType":"msg","x":240,"y":240,"wires":[["265e9470.f5b29c","49883eac.45546"]]},{"id":"7c39a75f.a236f8","type":"inject","z":"c1c06219.7371","name":"Enter the path to music folder here","topic":"","payload":"/home/pi/songs","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":240,"y":120,"wires":[["44492279.72883c"]]},{"id":"265e9470.f5b29c","type":"debug","z":"c1c06219.7371","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":550,"y":240,"wires":[]},{"id":"ae9850d0.8bcc9","type":"debug","z":"c1c06219.7371","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":550,"y":360,"wires":[]},{"id":"9647a584.97779","type":"change","z":"c1c06219.7371","name":"set up global object songlist","rules":[{"t":"set","p":"musicobj.songcount","pt":"global","to":"song_count","tot":"msg"},{"t":"move","p":"payload","pt":"msg","to":"musicobj.songlist","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":360,"wires":[["ae9850d0.8bcc9","9f1b663a.5047"]]},{"id":"9f1b663a.5047","type":"change","z":"c1c06219.7371","name":"set default volume","rules":[{"t":"set","p":"payload","pt":"msg","to":"220","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":190,"y":420,"wires":[["ab252747.61a3"]]},{"id":"ab252747.61a3","type":"link out","z":"c1c06219.7371","name":"to volume","links":["15dca399.f6aa14","dc3283bb.92a"],"x":335,"y":420,"wires":[]},{"id":"44492279.72883c","type":"change","z":"c1c06219.7371","name":"Set file path and musicobj global","rules":[{"t":"set","p":"fileURL","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"musicobj","pt":"global","to":"{\t   \"fileURL\"    : msg.fileURL,\t   \"audioURL\"   : msg.audioURL,\t   \"songcount\"  : 0,\t   \"songlist\"   : [],\t   \"songindex\"  : -1,\t   \"songtoplay\" : \"\",\t   \"action\"     : \"start\"     \t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":240,"y":180,"wires":[["9b2a50e4.6feb68","66efbfa6.aa3508"]]},{"id":"66efbfa6.aa3508","type":"debug","z":"c1c06219.7371","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":550,"y":180,"wires":[]},{"id":"de6b36f6.388348","type":"debug","z":"c1c06219.7371","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":550,"y":300,"wires":[]},{"id":"9d3aeef1.4d61f8","type":"comment","z":"c1c06219.7371","name":"ReadMe Music Player v1.0.0","info":"This music player reads a folder (called 'songs') and will play the songs in alphabetical order. \nOnce all the songs have been played, it will restart the list. \n\nYou can Pause/Resume play, Skip to the next song, go to the previous song and stop playing any songs.\n\nThere is also a button to power off the Pi.\n\nI designed this to allow it to be controled by an iPhone by turning on\nthe iPhone's Personal hotspot. To access it this way, you need to add the iPhone Hotspot name\nand password to the wpa_supplicant.config file on the Pi. ","x":200,"y":60,"wires":[]},{"id":"49883eac.45546","type":"change","z":"c1c06219.7371","name":"Get rid of hidden files and get count of songs","rules":[{"t":"set","p":"payload","pt":"msg","to":"[payload[$substring(0,1) != \".\"]]","tot":"jsonata"},{"t":"set","p":"song_count","pt":"msg","to":"$count(payload)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":270,"y":300,"wires":[["9647a584.97779","de6b36f6.388348"]]},{"id":"6a5d7cb.ff81384","type":"tab","label":"Music Engine","disabled":false,"info":""},{"id":"406e779c.6c7b78","type":"PlaySound","z":"6a5d7cb.ff81384","name":"","playerOptions":"{}","audioURI":"","options":"{}","x":730,"y":300,"wires":[["9124d974.eb418","9534da70.b643d8"]]},{"id":"9124d974.eb418","type":"debug","z":"6a5d7cb.ff81384","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":910,"y":300,"wires":[]},{"id":"9104b8c9.663f4","type":"catch","z":"6a5d7cb.ff81384","name":"","scope":null,"uncaught":false,"x":180,"y":380,"wires":[["e6bb71ad.6c646"]]},{"id":"e6bb71ad.6c646","type":"debug","z":"6a5d7cb.ff81384","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":430,"y":380,"wires":[]},{"id":"eb681c07.0df9f","type":"switch","z":"6a5d7cb.ff81384","name":"Actions","property":"musicobj.action","propertyType":"global","rules":[{"t":"eq","v":"previous","vt":"str"},{"t":"eq","v":"end","vt":"str"},{"t":"eq","v":"next","vt":"str"},{"t":"eq","v":"start","vt":"str"},{"t":"eq","v":"stop","vt":"str"},{"t":"eq","v":"pause","vt":"str"},{"t":"eq","v":"resume","vt":"str"}],"checkall":"true","repair":false,"outputs":7,"x":180,"y":240,"wires":[["3bd212ca.a6aee6"],["d15d4dae.7daef"],["d15d4dae.7daef"],["d15d4dae.7daef"],["b19fbd0.4ad1f4"],["b19fbd0.4ad1f4"],["b19fbd0.4ad1f4"]],"outputLabels":["","song ended","","","","",""]},{"id":"ed1057a7.128a78","type":"ui_text","z":"6a5d7cb.ff81384","group":"e2995cd7.b9add","order":1,"width":"6","height":"1","name":"Display song name on dashboard","label":"Now playing: ","format":"{{msg.payload}}","layout":"col-center","x":800,"y":180,"wires":[]},{"id":"986294f8.e1878","type":"change","z":"6a5d7cb.ff81384","name":"Get song name - strip out \".wav.\"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$globalContext(\"musicobj.songplaying\")","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$replace(payload, \".wav\", \"\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":800,"y":240,"wires":[["ed1057a7.128a78"]]},{"id":"15dca399.f6aa14","type":"link in","z":"6a5d7cb.ff81384","name":"Check Action","links":["6c3cbc3d.d183f4","8a62210b.718a","a86ea6df.2170a8","ab252747.61a3","53ea45ee.eda144","290be014.9360c8"],"x":75,"y":240,"wires":[["eb681c07.0df9f"]]},{"id":"6c3cbc3d.d183f4","type":"link out","z":"6a5d7cb.ff81384","name":"","links":["15dca399.f6aa14"],"x":895,"y":380,"wires":[]},{"id":"3bd212ca.a6aee6","type":"change","z":"6a5d7cb.ff81384","name":"Get prior song ","rules":[{"t":"set","p":"musicobj.songindex","pt":"global","to":"$globalContext(\"musicobj.songindex\") - 1","tot":"jsonata"},{"t":"set","p":"musicobj.songindex","pt":"global","to":"($globalContext(\"musicobj.songindex\")  >= 0)  ?  $globalContext(\"musicobj.songindex\") : $globalContext(\"musicobj.songcount\") - 1\t","tot":"jsonata"},{"t":"set","p":"song_name","pt":"msg","to":"$globalContext(\"musicobj.songlist\")[$globalContext(\"musicobj.songindex\")]","tot":"jsonata"},{"t":"set","p":"musicobj.action","pt":"global","to":"play","tot":"str"},{"t":"set","p":"musicobj.songplaying","pt":"global","to":"song_name","tot":"msg"},{"t":"set","p":"audioURI","pt":"msg","to":"\"/home/pi/songs/\"&song_name","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"start","tot":"str"},{"t":"set","p":"options","pt":"msg","to":"{\"afplay\": [ \"-r\", 0.5, \"-t\", 2.5, \"-v\", 1 ], \"mplayer\": [ \"-volume\", 1 ] }","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":200,"wires":[["986294f8.e1878","406e779c.6c7b78"]]},{"id":"d15d4dae.7daef","type":"change","z":"6a5d7cb.ff81384","name":"get next song","rules":[{"t":"set","p":"musicobj.songindex","pt":"global","to":"($globalContext(\"musicobj.songindex\")+1) > ($globalContext(\"musicobj.songcount\")-1) ? 0 : $globalContext(\"musicobj.songindex\")+1","tot":"jsonata"},{"t":"set","p":"song_name","pt":"msg","to":"$globalContext(\"musicobj.songlist\")[$globalContext(\"musicobj.songindex\")]","tot":"jsonata"},{"t":"set","p":"musicobj.action","pt":"global","to":"play","tot":"str"},{"t":"set","p":"musicobj.songplaying","pt":"global","to":"song_name","tot":"msg"},{"t":"set","p":"audioURI","pt":"msg","to":"\"/home/pi/songs/\"&song_name\t","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"start","tot":"str"},{"t":"set","p":"options","pt":"msg","to":"{\"afplay\": [ \"-r\", 0.5, \"-t\", 2.5, \"-v\", 1 ], \"mplayer\": [ \"-volume\", 1 ] }","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":240,"wires":[["406e779c.6c7b78","986294f8.e1878"]]},{"id":"9534da70.b643d8","type":"change","z":"6a5d7cb.ff81384","name":"set global action","rules":[{"t":"set","p":"musicobj.action","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":380,"wires":[["6c3cbc3d.d183f4"]]},{"id":"b19fbd0.4ad1f4","type":"change","z":"6a5d7cb.ff81384","name":"set action","rules":[{"t":"set","p":"payload","pt":"msg","to":"musicobj.action","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":280,"wires":[["406e779c.6c7b78"]]},{"id":"fd46bb5c.00a54","type":"comment","z":"6a5d7cb.ff81384","name":"send response from playsound back to actions","info":"","x":840,"y":340,"wires":[]},{"id":"8767759.079d608","type":"comment","z":"6a5d7cb.ff81384","name":"send response from playsound back to actions","info":"","x":300,"y":160,"wires":[]},{"id":"2bc0f655.2eaa92","type":"comment","z":"6a5d7cb.ff81384","name":"Watch for unexpected errors","info":"","x":240,"y":340,"wires":[]},{"id":"c1f6639f.eaecb8","type":"comment","z":"6a5d7cb.ff81384","name":"This is the music engine processing all the buttons","info":"","x":570,"y":80,"wires":[]},{"id":"224d605b.c4bd28","type":"tab","label":"Player Controls","disabled":false,"info":""},{"id":"39c0a9b7.b854de","type":"exec","z":"224d605b.c4bd28","command":"amixer cset numid=1 ","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":440,"y":200,"wires":[["5efa42e0.af4104"],["6316927a.17de7c"],["749374ae.cb1e3c"]]},{"id":"5efa42e0.af4104","type":"debug","z":"224d605b.c4bd28","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":730,"y":160,"wires":[]},{"id":"6316927a.17de7c","type":"debug","z":"224d605b.c4bd28","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":730,"y":200,"wires":[]},{"id":"749374ae.cb1e3c","type":"debug","z":"224d605b.c4bd28","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":730,"y":240,"wires":[]},{"id":"575f4365.4c3e04","type":"ui_slider","z":"224d605b.c4bd28","name":"Volume","label":"","tooltip":"","group":"bcdf1bbc.f314e","order":2,"width":"6","height":"1","passthru":true,"outs":"all","topic":"","min":"118","max":"235","step":1,"x":180,"y":140,"wires":[["1ccf7602.3d40da"]]},{"id":"1ccf7602.3d40da","type":"trigger","z":"224d605b.c4bd28","op1":"","op2":"","op1type":"nul","op2type":"payl","duration":"250","extend":true,"units":"ms","reset":"","bytopic":"all","name":"","x":200,"y":200,"wires":[["39c0a9b7.b854de","575f4365.4c3e04","def17d.2b9ca68"]]},{"id":"def17d.2b9ca68","type":"range","z":"224d605b.c4bd28","minin":"118","maxin":"235","minout":"0","maxout":"10","action":"clamp","round":true,"property":"payload","name":"","x":170,"y":260,"wires":[["30fe44e.5a143bc"]]},{"id":"30fe44e.5a143bc","type":"ui_level","z":"224d605b.c4bd28","group":"bcdf1bbc.f314e","order":3,"width":"6","height":"2","name":"UI_Level","label":"","colorHi":"#e60000","colorWarn":"#ff9900","colorNormal":"#00b33c","colorOff":"#595959","min":0,"max":"10","segWarn":"","segHigh":"","unit":"","layout":"sh","channelA":"","channelB":"","decimals":0,"animations":"reactive","shape":"3","colorschema":"rainbow","x":400,"y":260,"wires":[]},{"id":"5e20f800.472658","type":"ui_text","z":"224d605b.c4bd28","group":"bcdf1bbc.f314e","order":1,"width":"6","height":"1","name":"","label":"Volume","format":"","layout":"col-center","x":180,"y":100,"wires":[]},{"id":"dc3283bb.92a","type":"link in","z":"224d605b.c4bd28","name":"volume","links":["ab252747.61a3","b4a40821.1094d8"],"x":55,"y":140,"wires":[["575f4365.4c3e04"]]},{"id":"d1d0c70e.6e9f9","type":"ui_template","z":"224d605b.c4bd28","group":"85720886.d08da","name":">>","order":3,"width":"2","height":"2","format":"\n<md-button class=\"vibrate filled touched bigfont rounded\" style=\"background-color:#2980b9\"   ng-click=\"send({payload: 'Hello World big blue'})\"> \n    >>\n</md-button> \n\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":150,"y":576,"wires":[["2af0686d.edca5","beb45749.39c7"]]},{"id":"3ecd7c9e.1cfa74","type":"ui_template","z":"224d605b.c4bd28","group":"85720886.d08da","name":"<<","order":1,"width":"2","height":"2","format":"\n<md-button class=\"vibrate filled touched bigfont rounded\" style=\"background-color:#c0392b\" ng-click=\"send({payload: 'Hello World big red'})\"> \n   &lt;&lt;\n</md-button> \n\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":150,"y":416,"wires":[["ecc9799d.720eb8","2af0686d.edca5"]]},{"id":"89e52406.0e0358","type":"ui_template","z":"224d605b.c4bd28","group":"85720886.d08da","name":"Play/Pause","order":2,"width":"2","height":"2","format":"<md-button class=\"filled touched bigfont rounded vibrate\" \n    style=\"background-color:#27ae60\" \n    ng-click=\"send({payload:1})\" > \n   Play/<br/>Pause\n</md-button> \n","storeOutMessages":false,"fwdInMessages":true,"templateScope":"local","x":170,"y":496,"wires":[["1f595443.16ff64"]]},{"id":"f9c772d0.33f17","type":"ui_template","z":"224d605b.c4bd28","group":"85720886.d08da","name":"Styling for player buttons","order":5,"width":"6","height":"1","format":"<style>\n  .filled { \n      height: 100% !important;\n\n      padding: 0 !important;\n      margin: 0 !important;\n  }\n  .nr-dashboard-template {\n      padding: 0;\n      margin: 0;\n  }\n  \n  .rounded {\n  border-radius: 12px 12px 12px 12px;\n}\n \n   .bigfont {\n  font-size: 18px;\n}\n\n   .smallfont {\n  font-size: 12px;\n}\n  \n</style>\n\n<script>\n$('.vibrate').on('click', function() {\n  navigator.vibrate(100);\n});\n\nfunction restore_bg(x) {\n            $(this).css(\"background-color\", x);\n    };\n\n$('.touched').on('mousedown', function() {\n    \n    var x= $(this).css(\"background-color\");\n    $(this).css(\"background-color\", \"yellow\");\n    \n    setTimeout(restore_bg.bind(this,x),100);\n    navigator.vibrate(80);\n    });\n    \n</script>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":590,"y":376,"wires":[[]]},{"id":"7c0c9248.2416ac","type":"change","z":"224d605b.c4bd28","name":"pause","rules":[{"t":"set","p":"musicobj.action","pt":"global","to":"pause","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"pause","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":476,"wires":[["290be014.9360c8"]]},{"id":"290be014.9360c8","type":"link out","z":"224d605b.c4bd28","name":"Play/pause","links":["15dca399.f6aa14"],"x":675,"y":496,"wires":[]},{"id":"d15fc5f7.c602a8","type":"comment","z":"224d605b.c4bd28","name":"Stop","info":"","x":150,"y":616,"wires":[]},{"id":"82bd4df7.1b63f8","type":"comment","z":"224d605b.c4bd28","name":"Previous Song","info":"","x":180,"y":376,"wires":[]},{"id":"5ee5be59.84e6b8","type":"comment","z":"224d605b.c4bd28","name":"Play/Pause sound","info":"This section handles the Play/Pause switch.\n\nWhen a song is selected (above) the song is started and then\nimmediately paused. Because of this, 'play' is actually 'resume'.\n\nAt startup, the global that holds the play/pause value is empty\nso it defaults to \nWhen the button is pressed, ","x":190,"y":456,"wires":[]},{"id":"ca4426f4.fece4","type":"comment","z":"224d605b.c4bd28","name":"Next Song","info":"","x":160,"y":536,"wires":[]},{"id":"a7d29f70.ac458","type":"ui_button","z":"224d605b.c4bd28","name":"","group":"85720886.d08da","order":4,"width":"6","height":"1","passthru":false,"label":"Stop","tooltip":"","color":"","bgcolor":"","icon":"","payload":"1","payloadType":"str","topic":"","x":150,"y":656,"wires":[["2af0686d.edca5"]]},{"id":"53ea45ee.eda144","type":"link out","z":"224d605b.c4bd28","name":"Stop","links":["15dca399.f6aa14"],"x":675,"y":656,"wires":[]},{"id":"2af0686d.edca5","type":"change","z":"224d605b.c4bd28","name":"Stop","rules":[{"t":"set","p":"musicobj.action","pt":"global","to":"stop","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":656,"wires":[["53ea45ee.eda144"]]},{"id":"db307fd9.72383","type":"change","z":"224d605b.c4bd28","name":"next","rules":[{"t":"set","p":"musicobj.action","pt":"global","to":"next","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"next","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":576,"wires":[["a86ea6df.2170a8"]]},{"id":"e14c2072.9719","type":"change","z":"224d605b.c4bd28","name":"previous","rules":[{"t":"set","p":"musicobj.action","pt":"global","to":"previous","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":416,"wires":[["8a62210b.718a"]]},{"id":"8a62210b.718a","type":"link out","z":"224d605b.c4bd28","name":"to previous","links":["15dca399.f6aa14"],"x":675,"y":416,"wires":[]},{"id":"1f595443.16ff64","type":"switch","z":"224d605b.c4bd28","name":"Flip","property":"musicobj.action","propertyType":"global","rules":[{"t":"eq","v":"resume","vt":"str"},{"t":"eq","v":"initilize","vt":"str"},{"t":"eq","v":"play","vt":"str"},{"t":"eq","v":"next","vt":"str"},{"t":"eq","v":"previous","vt":"str"},{"t":"eq","v":"pause","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":7,"x":350,"y":496,"wires":[["7c0c9248.2416ac"],["7c0c9248.2416ac"],["7c0c9248.2416ac"],["7c0c9248.2416ac"],["7c0c9248.2416ac"],["1026c9df.fbe996"],["1026c9df.fbe996"]]},{"id":"1026c9df.fbe996","type":"change","z":"224d605b.c4bd28","name":"play (resume)","rules":[{"t":"set","p":"musicobj.action","pt":"global","to":"resume","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"resume","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":516,"wires":[["290be014.9360c8"]]},{"id":"beb45749.39c7","type":"delay","z":"224d605b.c4bd28","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":360,"y":576,"wires":[["db307fd9.72383"]]},{"id":"a86ea6df.2170a8","type":"link out","z":"224d605b.c4bd28","name":"to 'song end' check","links":["15dca399.f6aa14"],"x":675,"y":576,"wires":[]},{"id":"ecc9799d.720eb8","type":"delay","z":"224d605b.c4bd28","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":360,"y":416,"wires":[["e14c2072.9719"]]},{"id":"f3e0a773.8df6f8","type":"comment","z":"224d605b.c4bd28","name":"This code handles the dashboard volume controls and uses and EXEC to call AMIXER","info":"","x":400,"y":40,"wires":[]},{"id":"d61cd8f6.1fae7","type":"comment","z":"224d605b.c4bd28","name":"This code handles the dashboard player controls","info":"","x":280,"y":336,"wires":[]},{"id":"1e4469c9.e848f6","type":"tab","label":"shutdown","disabled":false,"info":""},{"id":"2674ae89.89529a","type":"inject","z":"1e4469c9.e848f6","name":"Press to shutdown the Pi","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":140,"wires":[["91f984a1.8bd008"]]},{"id":"91f984a1.8bd008","type":"exec","z":"1e4469c9.e848f6","command":"sudo poweroff","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"poweroff","x":460,"y":140,"wires":[["ad983b0.4bc1548"],["3451e19d.a7086e"],["e6e62a51.ce9f9"]]},{"id":"ad983b0.4bc1548","type":"debug","z":"1e4469c9.e848f6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":650,"y":100,"wires":[]},{"id":"3451e19d.a7086e","type":"debug","z":"1e4469c9.e848f6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":650,"y":140,"wires":[]},{"id":"e6e62a51.ce9f9","type":"debug","z":"1e4469c9.e848f6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":650,"y":180,"wires":[]},{"id":"2ae00eff.c1689a","type":"ui_button","z":"1e4469c9.e848f6","name":"","group":"acb5989b.bc373","order":1,"width":0,"height":0,"passthru":false,"label":"Power off Pi","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":150,"y":80,"wires":[["91f984a1.8bd008"]]},{"id":"22d848f3.fa7d2","type":"comment","z":"1e4469c9.e848f6","name":"Two ways to shutdown the Pi","info":"","x":200,"y":40,"wires":[]},{"id":"e2995cd7.b9add","type":"ui_group","z":"","name":"now playing","tab":"3aff5f59.0a6d88","order":1,"disp":false,"width":"6","collapse":false},{"id":"bcdf1bbc.f314e","type":"ui_group","z":"","name":"volume control","tab":"3aff5f59.0a6d88","order":2,"disp":false,"width":"6","collapse":false},{"id":"85720886.d08da","type":"ui_group","z":"","name":"play controls","tab":"3aff5f59.0a6d88","order":3,"disp":false,"width":"6","collapse":false},{"id":"acb5989b.bc373","type":"ui_group","z":"","name":"Shutdown Pi control","tab":"3aff5f59.0a6d88","order":4,"disp":true,"width":"6","collapse":false},{"id":"3aff5f59.0a6d88","type":"ui_tab","z":"","name":"Music Controls","icon":"dashboard","order":1,"disabled":false,"hidden":true}]
Hi, really nice setup
could you tell me what a message should look like which triggers an mp3 file to play with the "PlaySound" Node ?
For Example if i want to use the command for the sox player "play /home/pi/music/song.mp3" ... how would the function node look like, which pumps the signal to "PlaySound" ?
Kind regards
Marten
I put some notes in the play-sound github page https://github.com/MattVador/node-red-contrib-play-sound/issues/6 about using aplay, don't know if they will help you or not.
figgured it out later yesterday ... so easy :smiley:
just if anyone else needs a quick example ^^
Does this flow show how you output to the HifiBerryAmp? I can't seem to figure out that piece.
if you look on the hat next to the 4 input header there is a line of code
dtoverlay=hihiberry-dac
that you need to add to the config.txt file.
at least you did need to do it back in 2019 :grin:
p.s. that file is /boot/config.txt
Thanks so much for the reply.
I think maybe i'm a little confused still.
I have 1st rasp pi running node red and a 2nd rasp pi with the hifiberry amp, which has hifiberry OS.
Do I add the dtoverlay=hifiberry-amp to the 1st rasp pi? I tried that, and it didn't seem to do anything. Is there a way to send a signal to the HiFiBerry Pi from the Node Red Pi to play the files? If I use a dlna-action-node it finds the Pi Server. Sorry I'm a bit new to node red flows.
Remember, this project was done back in November of 2019 using the HiFiBerry MiniAmp. The dtoverlay goes on the Pi that has the HiFiBerry MiniAmp attached to it.
I missed that you are using a HiFiBerry Amp so you may not need that overlay. I've also not used HiFiBerry OS so I really can't tell you what you need to do.
If you want the Pi running NR to talk to the other Pi running HiFiBerry OS you will have to look at the documentation (and support) of HiFiBerry OS and see if it has an API you can use to communicate between the two. That link will also show you where you can ask them questions.
Thanks Paul, appreciate the help! Maybe I need to remove the HiFiBerry OS and just try to run with it using that config connection. I'll check with the HiFiBerry forums and support and see if I can make it work otherwise.
That's was just my typo when I edited the text for this post.
Appreciate that you took your time to put my post to new thread.
