Node-red-contrib-sonoff-tasmota
Tried to install the tasmota tools and got the following result... dont really know what to make of this
pi@raspberrypi:~/.node-red $ npm install node-red-contrib-sonoff-tasmota
(node:14414) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
npm WARN package.json node-red-contrib-graphs@0.3.5 license should be a valid SPDX license expression
node-red-contrib-sonoff-tasmota@3.0.0 node_modules/node-red-contrib-sonoff-tasmota
└── debug@2.6.9 (ms@2.0.0)
What came after that ? - It looks like a warning rather than an error... (so far)...
Basically it means it's an old node and about the break soon when they finally remove the os.tmpDir() function... and the packaging of the node could be improved with a more correct license clause... but as long as it's just a waring... it should be ok... (for now).
that was the end of the output from the command line... it does not appear to have added tasmota node tools to the node-red gui
What version of npm are you using? Running npm install doesn't run any code in the module you are installing, so it would not have triggered the DeprecationWarning. The only running code is npm itself. So, the question is what version of npm and node are you using? What's the result of:
npm -v
node -v
pi@raspberrypi:~/.node-red $ npm -v 1.4.21
(node:16561) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
pi@raspberrypi:~/.node-red $ node -v v8.11.1
Yikes. Please upgrade it asap
Ideally follow our pi install / upgrade instructions on the docs page and use the script to upgrade
I would not bother using that node, it is easier IMO to communicate with the devices using MQTT. That is what most users do.
Thanks for all the help... still pretty new to python, node-red, Raspi... I'm using ESP32 with upython and MQTT to monitor some temps and control some outputs on the ESP32. I have some of the sonoff devices but have not modded any of them... are folks using the tasmota software on the sonoffs.
Absolutely.
There is an excellent tasmota support list
https://groups.google.com/forum/#!categories/sonoffusers
