Can not install a module
Hello
I have an error in module installation but how to get around it?
(node: 1916) [DEP0022] DeprecationWarning: os.tmpDir () is deprecated. Use os.tmpdir () instead.
Precision: I'm on RPI3 and Debian 9 Stretch
Thank you for your help
Luc
What version of nodejs, node-red and npm are you using?
Hello
Node-RED: v0.19.3
Version Node.js: v8.11.1
Npm: 1.4.21
An upgrade of npm does not work I always have the same error
"(node: 1559) [DEP0022] DeprecationWarning: os.tmpDir () is deprecated. Use os.tmpdir () instead."
Thank for help
your version of npm is too old.
If this is on a raspberry pi, it is worth updating using the script in the docs.
Otherwise just update npm
So if you have updated npm what version are you now on?
Hey no, he does not get up to date precisely, I have the same mistake.
... Upgrading from node-red to 19.4 instead of .19.3
That's what shows me when installing the module
Oct 21 14:24:55 - [warn] (node: 2287) [DEP0022] DeprecationWarning: os.tmpDir () is deprecated. Use os.tmpdir () instead.
npm ERR! Error: unable to get local issuer certificate
npm ERR! at TLSSocket. (_tls_wrap.js: 1105: 38)
npm ERR! at emitNone (events.js: 106: 13)
npm ERR! at TLSSocket.emit (events.js: 208: 7)
npm ERR! at TLSSocket._finishInit (_tls_wrap.js: 639: 8)
npm ERR! at TLSWrap.ssl.onhandshakedone (_tls_wrap.js: 469: 38)
npm ERR! If you need help, you can report this * entire * log,
npm ERR! including the npm and node versions, at:
npm ERR! Http://github.com/npm/npm/issues
npm ERR! System Linux 4.14.71-v7 +
npm ERR! command "/ usr / bin / node" "/ usr / bin / npm" "install" "--save" "--save-prefix = ~" "--production" "node-red-dashboard@2.9.8"
npm ERR! cwd /root/.node-red
npm ERR! node -v v8.11.1
npm ERR! npm -v 1.4.21
npm ERR! UNABLE_TO_GET_ISSUER_CERT_LOCALLY code
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /root/.node-red/npm-debug.log
npm ERR! not ok code 0
21 Oct 14:24:55 - [warn] --------------------------------------- ---
That is upgrading Node-RED itself. Please tell us what version of NodeJS and npm you are using.
From a command line, run:
node --version && npm --version
v8.11.1
1.4.21
(node:2601) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
That is the same version you listed in your second post.
You then say "An upgrade of npm does not work I always have the same error"
npm v1 is too old. You need at least npm v2
Ok i'm looking at the site here for the way to upgrade but surely i'm doing it wrong
Do you have the right command line?
Thanks again for the attention
Cela dépend de l'ordinateur que vous utilisez
Linux Debian 9 stretch in RPI3.
Testing "Sudo npm outdated" is not good
Ensuite, utilisez le script dans la documentation.
If you are using a standard installation of Node-RED. Run Dave's upgrade script - see the Node-RED docs. That will upgrade node & npm to the right versions.
Since you are using Debian Stretch the upgrade script should work ok as Raspbian is based on that.
https://nodered.org/docs/hardware/raspberrypi
Always the same problem.
How can I completely destroy node-red and reinstall it properly?
I think going back to a clean node-red might be better ... no?
Running the script usually recovers the situation. What happens when you run the script? If it fails then post /var/log/nodered-install.log here.
I do not have a node-red log file in / var / logs /
concerns of node-red in itself but modules.
I have an error when installing these
So what is the exact command you are running?
What does it display?
Or just start with a brand new install of Stretch on the sd card
