Node-red-contrib-tabletojson not working
Node-red: 4.1.0
Node: 22.18.0
I have installed the latest version of node-red-contrib-tabletojson. The icon for the node is in the palette, I can copy it to the flow. When I try to deploy the flow, the error
Flow stopped due to missing node - tabletojson
shows up.
The directory $HOME/.node-red/node-modules/node-red-contrib-tabletojson exists
You need to look at your Node-RED log to see what error is happening.
That node hasn't been touched for 3 years and your next step is probably to raise an issue on GitHub.
I am seeing that too. It is a problem with the node. As suggested, try raising an issue on the github page.
