Imported a via palette manager a node
json-db-node-red.
Did not worked as I hoped it would.
After some trials witch did not worked for me I wanted to delete the node.
But the deploy button stays red and there is no response when I push it.
When I do a restart flows I get
"Deploy failed TypeError: runtime.flows.loadFlows is not a function"
I have stop/started node-red, no avail.
What can I do to get node-red running again.
Edit : after flushed the browser cache, Node-red started again with the deploy button grey, pfff
Edit 2 The problem exist, after I remove the node from the tab, the deploy gives the same old error above.
